Question about Whirlpool Washing Machines
I keep getting a failure with a code 2 before my front load loader whirlpool washer cycle is complete. The washer is about 7 years old.
  • 472 Answers
F 02 is a drain issue
check the drain hose make sure not plugged or kinked
check electrical connection at drain pump itself
on this unit there is a cleanout at bottom behind kick plate remove the 2 or 3 screws from bottom and you will see a a plastic clean out have a few towels ready or a wet vac works great...make sure you unplug unit during this as electricity and water do not mix well...
pull cover on clean out and check for any foreign material and while in there check pump impeller for coins also move hoses sometimes objects in hoses right before pump ....if all this does not correct you have a bad pump assembly most likely...
good luck and please vote...
Posted on Jan 03, 2011
Have a whirlpool front loader washer, about 7 years old, cycles getting stuck between door lock and add garment
Joanie, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Joanie), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool Washing Machines
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Whirlpool front loader washer is no completing cycle. I see a F 02 code falshiing. How ca i fix it?
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects HERE"S HOW
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
I have a manual and repair photos HERE
Jan 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS ERROR CODE 35 OR ERROR CODE 37? ON MY FRONT LOADER.WFW9600TA00
does it say f35 and sud?
you need a new pressure switch
sounds like a new washer is it 1-2 years old?
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer quits be for the spin cycle code pops up fo2 model # ghw9150pw4
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to Applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it.
Nov 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Service manual
Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Beeping on spin cycle
It is most likely out of balance, could be for many reasons.
1 could be too many heavy items such as jeans, towels, etc in one load.
2 could be the machine or floor is unlevel.
3 Could be a balance sensor needs replacing.
Mar 09, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
