Question about Maytag Performa PAV2200
Machine will not start. Timer dial clicks when it is pulled out, instead of starting.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.Replace the lid switch with this part.
Posted on Jan 03, 2011
My washing machine won't start. Here click but then nothing. Getting powere from house.
Most often I see this being the timer relay contacts being burned up. Pull the timer out and apart and you'll quickly see what I'm talking about. Your dial controls and is directly connected to the timer. They are typically around 85.00 when I've priced them.
Jan 04, 2015 | Asko Washing Machines
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
Apr 25, 2017 | LG WM Washing Machines
How do you get the knob off the timer
Timer is not identified.
If you have spring-wound timer, or EJ351 timer, or E1020 dial timer, the the dial pulls straight off.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have rotating-dial timer, the dial does not come off. Instead the plate snaps off.
http://waterheatertimer.org/images/GE-15070-wiring-1-500.jpg
If you have plug-in timer, or timer module, or power pack, or box timer, this type of timer dial does not come off as general rule.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 27, 2012 | General Electric Clothes Washer Timer -...
Will not turn on . started filled with water then shut off and will not power up now. it still has water in machine this washer is a little over one year old .
Sounds like the timer motor didnt engage. Soon as the fill switch activates, when its full, the timer motor advances forward and starts the cycle. Since the water stops when full. Then part of the switch is working. The one that is nc at same time the one that is no engages. Try advancing the dial couple clicks into the cyckle then pull back out.
May 31, 2010 | Washing Machines
No water goes into dishwasher. Dishwasher has only been used 2times. Came new with house 3.6 years ago. Pulled front panel off...everything appears to be connected motor fan runs.
I've experienced the same thing. Try very slowly rotating timer dial, click by click, until the water starts. Sometimes 3 or 4 clicks will start water. (You're advancing the clock.) Usually water starts in before the dial points to, "Short Wash." If this doesn't work, advance the dial to, "Off," unlock and open the door, reset, close, the soap dispenser, close and lock the door, and slowly advance the dial until the unit starts. I think this problem is a clock to pump issue and what I've described does a reset of the system. This happens to me once or twice per month. Poor engineering but still better than buying a new machine...at least 'till now.
Jan 04, 2010 | GE Nautilus 24" Built-in Dishwasher
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Indesit w1 13 reset
If your washer has some black spots on timer dial then set your dial pointer to one of these spots to reset programme.
Then try it again, if it still does the same thing, then you probably have a faulty control module.
Expensive!!!!!
Nov 06, 2008 | Indesit WA 115 Front Load Washer
Timer clicks arround and arround
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
Jul 02, 2007 | Belling SGE12X Front Load Washer / Dryer
Washing Machines Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
