Question about Whirlpool Washing Machines
What is the rated load size? - Whirlpool Washing Machines
  • 472 Answers
If you go online and type in your model number you will find a list of sites pick your model and manufacture it should give you this info if you do not have the manual that came with your unit ...
good luck /////please vote....
Posted on Jan 03, 2011
Is there a way to add a trailer towing package to this vehicle as I need to hall 4400 lbs?
No, the car is rated to tow a maximum of 1000 lbs unbraked, so you are way off.
You will need a heavier and more powerful vehicle, something like a Dodge Durango. Don't forget to factor in the weight of passengers and any other luggage.
Apr 17, 2015 | 2002 Chevrolet Impala
Will i have a problem installing 225/60/15 winter tires on my 1999 chevy tahoe
I pulled up your vehicle information in our fitment guide and tires in the 225/60/R15 and 225/60R16 sizes are not load rated for your vehicle. They are also quite a bit smaller than the tires that came on your Tahoe when new. Running a tire that is too small (even if it was load rated) will have an effect on your vehicles performance. We do not recommend installing either of these sizes for safety and performance reasons.
If your Tahoe came with 15" wheels we would recommend looking into the 235/75R15 size.
If your Tahoe came with 16" wheels we would recommend looking into the 245/75R16 or 235/75R16 sizes.
If you are still searching for some winter tire options please feel free to shop our website at www.discounttire.com or contact one of our local Discount Tire or America's Tire stores. We would love to help you find a great winter tire that will fit your Tahoe correctly and help keep you and your passengers safe.
Dec 14, 2013 | 1999 Chevrolet Tahoe
Can I put a higher watt heat tube in my TQ-10 converyer toaster
Your toaster is rated at 1800watts which is the power rating.
Your toaster is rated at 15amps which is the current rating.
Your toaster is rated at 120v which is the voltage rating.
Electrical Load,Power Rating and Current Drawn through the Main Supply is Calculated By: Power = Amps x Volts
1800=15x120=.........1800w.
Manufactures work out what size of cable and protectio to incorporate by using this design principle.
If you try to increase the bulb size it will alter everything and the internal wiring was not designed to take this extra load.
So, NO...
Oct 02, 2009 | Hatco Kitchen Appliances - Others
I need to install a power converter in my truck.Can any one help me with the basics? Please get back to me. Keith
What is it exactly that you want to accomplish? It looks like this unit is powered by the electrical system of your truck, but if it indeed can provide 2500 Watts of output power, its input demand from your truck electrical system will be in excess of 200 Amps!!! You'll need some pretty hefty wiring to support that type of demand, and I doubt if your alternator can put out that amount of current.
Are you sure you want/need to do this - and run it off your truck electrical system?
Sep 22, 2009 | Xantrex Technology DPS350KB 2500-Watt...
For an 3 Tn unit- single phase- 220 V a.c and gfor
There should be a full load amps or rated load amps on each of these units on the rating or nameplate. The ampacity or fuse size and wire size, which I think that's what you are wanting to know . The fuse size would be full or rated load amps times 125% and the wire size depending on the length of the run, 50 feet or less, (15 amps 14 gauge wire), (20 amps 12 gauge), (30 amps 10 gauge), and (40 amps 8 gauge).
Aug 11, 2009 | Heating & Cooling
Hp lj 4250 tray 1 stoped feeding automatically.
Here is the info from the service manual about tray configuration.
The value corresponds to the media size that is currently loaded in tray 1. ANY: If both the type and size for tray 1 are set to ANY, the printer will pull media from tray 1 first if media is loaded in the tray. A size other than ANY: The printer does not pull from tray 1 unless the type or size of the print job matches the type or size loaded in this tray.
So set both the paper size and type on tray one to "ANY" and you should be good to go.
I hope this helps, if so please rate my solution.
I have the full service manual available for instant download for $6.95 if you are interested.
Buddy
buddy@ccl-la.com
Corporate Computer
WWW.CCL-LA.COM
Jul 09, 2009 | Office Equipment & Supplies
A friend wants to know were the model number is and load size
Inside the lid will have the model # and capacity. If not - a tag right where the hoses connect is a likely spot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2009 | Kenmore Washing Machines
Mr slim unit
Let me try to send you to a quick fast electrical course on wiring size vrs amp draw it can carry before it burns into. The breaker box can send out the rated amps the wire comming into the box its sized for. (example. #3 can carry 10 amps) then it is distributed thru breaker thru the wires to the loads amp draw. depends on the maxium rated amp draw of the load, the wire can carry a certain amount of heat or amps. Ceck the max. rated amps or heat draw it can carry to size your wires & breaker,! thank you very much!
Dec 11, 2008 | Heating & Cooling
Need 3 phase contactor for keating deep fryer
You might try
http://www.grainger.com
You will have to determine the amperage size, voltage load size, and the coil voltage size. This info should be on the old contactor you can comment me if you need more help.
Hope this helps you
please rate me
Jul 18, 2008 | Keating Kitchen Appliances - Others
Washing Machines Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
