Question about Fisher Ovens
Hi, We have an older model Fisher and Paykel soft touch oven which is now giving an error message F4 and a beeting noise when switched on. Could you please advise what is causing the problem?
  • 1,711 Answers
The error F4 means that Open oven temperature sensor (RTD)
You need to Check sensor harness and harness connection between oven
sensor and oven control.
Replace oven temperature sensor (RTD) if wiring is
ok.
Posted on Jan 03, 2011
How do you start the clock on Fisher & Paykel
Fisher and Paykel does not know that model number. Could you recheck it please and advise us?
May 09, 2016 | Fisher Ovens
I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Jul 01, 2011 | Fisher and Paykel Ovens
Fisher Paykel oven model OS302M error code F7?
Check your lock on the oven for the door. It may be sticking out a bit:)
Oct 01, 2010 | Fisher and Paykel AeroTech Double OD302...
F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Jul 14, 2010 | Fisher and Paykel Ovens
Fisher paykel double soft touch oven just came up with c2 and wont stop beeping
shut off the power for 5 min and try again . you will find inside the control panel a tec sheet with this code . it should help / thanks mm
Dec 02, 2009 | Ovens
Dacor Oven F4 error message
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
May 18, 2009 | Dacor ECS130 Epicure Electric Single Oven
Rubbing sound-like noise when switching bottom oven on
most likly the fault is the fan blades touching the side of the circular hole,to test.1.switch of all power.2.when power is switched of try switching your oven to on position.if oven will not work then proceed3.if you can turn the fan blades by useing a thin piece of wood or simler.4 if when you turn the blades you hear a rubbing noise you might take a closer look if you have torch point it in if you see the blades touching or one of the blades touching it might be possable to to push the offending blade back very slightley useing the same piece of wood you yoused at 3.if this fails to solve your problem the fan moter might be ready to give up. I hope this can solve your problem.yours adrian.
Feb 14, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
Fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Nov 12, 2008 | Fisher and Paykel AeroTech - OS302M...
1992 Frigidaire built-in oven with F4 error
f4 is the code for a shorted oven probe try first replacing it
Feb 12, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Ovens Logo
315 people viewed this question
Top Fisher Ovens Experts
Dennis Boxerman
Richard
Richard
ray gallant
Are you a Fisher Oven Expert? Answer questions, earn points and help others
