I have a Morphy Richards Electric blanket which when turned on works for about 5 minutes and then the power and active lights start flashing and turn the heating off. Once this has happened you can't turn the lights off by the switch, the plug has to be pulled out. Thanks
SOURCE: My Sunbeam electric blanket controls
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Posted on Dec 22, 2008
BIKER T
  • 909 Answers
SOURCE: Danby spac8006
sounds like compressor is defective and switching off on overload.or have someone check starting capacitor
Posted on Oct 24, 2007
  • 686 Answers
SOURCE: Red and green light flashing and wont work
PROBABLY A SHORT IN THE BANKET ITSELF AND IT SHUTS OFF TO PREVENT SHOCK OR FIRE.
Posted on Apr 28, 2009
  • 17 Answers
SOURCE: TOYO TA-09CHS aircon problem
Okay, let do this;
Turn unit On and go out to condenser unit and see if the cooling fan motor is runing and strong.
I sure you cooling fan motor is not working.
Once the comoressor protector detected over heat it shut it seld down.
nguyen@ite.net
Posted on Jun 09, 2009
  • 9 Answers
SOURCE: hi, i have 2 daikin air conditioning unit, 1 is
The flashes are codes for different problems the unit may have, count the flashes and check your owners manual this will tell you the problem and the solution, or turn the breaker off for 5 minutes and re-start the unit this will reset it the unit should work if the problem start again you will need a service man. hope I was able to help you.
Posted on Jan 29, 2010
How to use a morphy richards icon breadmaker
The blinking 5 E L code indicates a fault that needs to be corrected before you can continue making bread.
Jun 24, 2016 | Morphy Richards Kitchen Appliances -...
Ive brought a second hand morphy richards icon stainless steel bread maker ive done every thing with the ingredience pluged it in press select and it is flashing 5EL isnt working
probably is why it is second hand -- it had the problem for the previous owner who failed to disclose that it wouldn't work
go google and type in--- user manual for morphy richards bread maker--- and if there is a manual in pdf version down load it and see if there is a trouble shooting section
Where can i get manual for morphy richardscombi microwave.ac925efp
Free Morphy Richards Kitchen Appliance User Manuals ...
kitchen.manualsonline.com/manuals/.../morphy.../morphy_richards_pro...
Morphy Richards Electric Pressure Cooker User Manuals. Get Manuals; Support ...Morphy Richards Hot Beverage Maker User Manuals. Get Manuals; Support
Oct 30, 2015 | Morphy Richards AC925EFP...
Morphy Richards 43960 kettle won't boil,even thou the light is on. This kettle is only 14 mths old
There is a therm o guard in there looks like a bullet. anything that has a heating element has one. mouser electronics sells them.
Oct 20, 2014 | Morphy Richards 43072 Cordless Electric...
Hi there Hiw can I turn off the whistle on the Morphy Richards Accent kettle please?
You can turn off the electronic whistle on the morphy richards kettle by moving the switch (marked with a musical note) which is located underneath the electric base unit (not on the kettle itself).
Mar 03, 2011 | Morphy Richards 43691 Cordless Electric...
Morphy richards electric blanket --how to use it
the 0 and 3 settings are to set it to come on in 3 hours (0 being off). the 1,3,12 settings are for it to turn off automatically after that amount of hours. I can remember what the 1/2 button in middle is for.
Jan 27, 2010 | Heating & Cooling
Apr 27, 2009 | Washing Machines
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
