Question about Canon Photography
I've just loaded the film into my Canon A-1, and I tried to advance it to the first frame, but nothing seems to be catching the film, and the shutter button doesn't seem to be doing anything either. Please help!
    Problem Solver:
  • 11 Answers
What has probably happened is that you have not yet engaged the sprockets into the sprocket holes in the film. Open the back and make sure the film is being pulled by the take up spool under the wind on lever until both top and bottom sprockets are engaged. If there are any torn sprocket holes in the film, cut the damaged film off, cut a new lead in section to half film width, and try again. You will lose a few shots, but the rest of the film will be fine. Shutter won't start working until the film is properly advanced. If you need to get damaged film off the take up spool just press the film return button, the one you would press the rewind the film into the can at the end of the film. It is on the bottom under the sprocket shaft.
Posted on Jan 09, 2011
Why is my canon ae-1 only developing blank film
First thing I would do is sacrifice a roll of film. Load the film as you have been. Then with the back open and tension on the film (do not touch the film over the shutter, advance the film. It may be that you are putting the film on the takeup spool incorrectly. Watch how the film advances on the spool. If it is on the spool incorrectly it will disconnect then not advance. If that does not work it may be a errant takeup spool.
Jul 06, 2012 | Canon EOS-AE-1 35mm SLR Camera
My shutter got stuck at 14 frames.i wound it back but want to go back to the 14th frame,will this ruin the pictures i have already taken?
Could be that when the load builds up there is friction to jam the film. You must not take chance with the shot film and so try to click with the cap on the rewound portion and if the film is not advancing then it is possible that the camera must be checked with a dummy film to confirm on why the jamming takes place.It can be also due to failure of the loading mechanism
Mar 17, 2012 | Canon EOS-AE-1 35mm SLR Camera
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
Blank Film Developing
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Takes a picture when film advance lever is moved
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Photography Logo
153 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
