Question about Bosch 24 in. SHU43 Built-in Dishwasher
Water inlet valve Bosch
Do you know the part number?
I ordered the part through reliable parts in Richmond BC. I no longer have the box with the part number but I called the Bosch 800 number to find the part number.
Posted on Jul 09, 2008
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
The water supply line to my Bosch dishwasher (model # shx46a06uc/21) froze. We didn't realize this and tried to run the dishwasher. Now the line is unfrozen, but the dishwasher still won&#
Check for water supply to the valve. Check for 120vac at the valve during fill cycle. If you have both, the water inlet valve is bad, part number 00425458.
Jan 12, 2015 | Bosch Dishwashers
Sgu 5602
If you are able to select wash programs and the panel is responding then most likely the water inlet valve is faulty and needs replacement. I am assuming you are hearing a click but no water comes through. Also check the inlet water tap under kitchen sink.
The valve for your dishwasher should be like this
http://www.bosch-home.co.uk/store/product/Valveaquastop/00263789
However, the problem can be more complicated if your dishwasher uses water softener unit. Will need the full model number to verify this. For example SGU5602/xx
You can also view all the parts at this site http://www.bosch-home.com/us/store/spareparts/Dishwashers60cmbuiltinbuiltunder/SGU5602/03
Apr 22, 2014 | Bosch Dishwashers
Dishwasher will not fill with water when turned on
Hi and welcome to FixYa, I am Kelly
The following steps require using electrical power. You assume all responsibility / risk for any mis-fortunes cause by working on this dishwasher with power applied.
The first step will require using a meter on the water valve solenoid teminals.
- Remove all power.
- Remove the lower toe / kick panel(s).
- Locate the main water supply line and follow that to the inlet water valve.
- Slide the connector(s) off of the solenoid and read resistance on meter scale R x 1 or R x 10. You should read a low resistance. If you do not read any resistance the inlet water valve has failed.
If you do read resistance you must check switch the meter to AC voltage and apply power and read for AC voltage on the teminals of the wire harness.
- Start a reular wash cycle to where the unit should be filing with water.
it SHOULD read 120 VAC.
If you have no power at the connector teminals
- Check the float switch plastic FLOAT. If the float is stuck in the UP position due to food particulate on the FLOAT stem you willnot have power to the inlet water valve solenoid.
If you have power to inlet water valve solenoid and it is buzzing / humming but you get no water there is debris in the main water supply line. You wil have to shut off the water supply and clean out the inlet of the water valve.
The inlet water valve replaement part is here:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=233229
Detailed View
http://www.appliancepartspros.com/Appliance-Parts/bosch-water-inlet-valve-assembly-item-number-ap3783031.aspx
This is what the float looks like:
http://www.appliancepartspros.com/Appliance-Parts/bosch-float-item-number-ap2802399.aspx
This is the level switch assembly:
http://www.appliancepartspros.com/Appliance-Parts/bosch-level-switch-assembly-item-number-ap2802390.aspx
This is the actual Float switch: (3 terminal)
http://www.appliancepartspros.com/Appliance-Parts/bosch-float-switch--3-terminal--item-number-ap2802373.aspx POWER to the inlet water valve solenoid comes from this switch.
Check for s stuck float... and that the level switch is actuated as the float id lifed gently up and down. If you do not hear a micro-switch click the switch is bad. If the float is hard to move... clean it as best you can so that it moves freely up and down.
One of the above is causing your problem.
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | Bosch SHU9915UC Dishwasher
My Bosch works very well.But when you idol it for several days, there will be a lot of water, if you don't clean up,soon or late got overflowed
If the dishwasher is filling to overflow level when not in use, you need to replace the water inlet valve/solenoid assembly. The valve is not closing fully allowing water to seep into the washer.
If you have a check valve for the water supply to the dishwasher, I'd suggest closing the check valve while the washer is not in use until the inlet valve has been replaced. If you don't have a check valve, if you leave the power switched on, the washer will automatically pump out when it reaches overflow level. The anti-flood protection system will stop the dishwasher overflowing as long as the power is on. Closing the check valve is by far the best option!
The inlet valve/solenoid is located behind the toe-kick below the door and is relatively easy to replace yourself. The only tools required are a Torx T20 screwdriver for removing the toe-kick and the valve.
If you are confident that you can undertake this repair yourself and have the tools, I've listed the part/supplier details and fitting instructions below. If you would prefer to call a service technician, make sure you aren't charged more than $30-35 and no more than an hour for labor.
Please note: This part relates to the Bosch SHX45M05UC/xx. If you do not have this model, verify the correct part number for your model before ordering.
Part number: 607335
Description: Water inlet valve (sometimes called water inlet or valve access)
This part is used on all versions of SHX45M05UC/xx, so it doesn't matter if the 'xx' on your model is 01, 02, 06, 12, etc.
Suppliers:
Bosch - $28.10 plus shipping (in stock)
http://www.bosch-eshop.com/eshop/bosch/us/prodls.htm?Matnr=000000000000607335&ESHOPTYPE=A
Sears Parts Direct - $24.49 + shipping (on backorder)
http://www.searspartsdirect.com/partsdirect/part-number/Bosch-Parts/Dishwasher-Parts/607335/0022/630/Model-SHX45M05UC48/1794/0130000?keySuffixId=NA&productTypeId=x&searchModelNumber=SHX45M05UC48
There is an option on this page to check part availability at local stores.
Appliance Part Pros - $29.21 + shipping (in stock)
http://www.appliancepartspros.com/part_details.aspx?part_id=4070550&pn_=607335
(APP use their own part numbering. This part is listed as AP4070550)
Fitting instructions:
1. Switch off the power at the breaker and close the water supply check valve
2. Clear as much water from the sump as possible - a turkey baster works well for this
3. Remove the two Torx T20 screws from the toe-kick then tilt the toe kick out to remove it
4. Remove the base insulation (if fitted)
5. Disconnect the water supply line from the inlet valve
6. Make sure the sump inlet hose is clear of the inlet valve
7. Disconnect the wires from the water valve - make note of where to re-attach first!
8. Remove the two Torx T20 screws from the inlet valve
9. Pull out the inlet valve and disconnect the hose
A small amount of water will drain from the hose when you disconnect it (assuming you drained the sump first) so have something ready to catch the water if possible.
That's it. Refitting is the exact reverse of the above. This is a relatively simple repair, but it's a good idea to take digital photos as you go along so you can refer back to them when re-fitting parts.
Hope this helps. If you have any questions or need assistance should you decide to replace the valve yourself, please let me know.
Regards,
BElectric
Apr 29, 2011 | Bosch Integra 500 SHX45M05UC Stainless...
The water inlet valve dose not work, therefor the machin can not start. The inlet water signal light is off, however I checked the water pressure that was ok, also there is a noise in the valve. Is the...
Welcome to FixYa.
Based on your description, "The water inlet valve dose not work...also there is a noise in the valve. Is the valve is damaged???"... and to answer your question, the issue is likely with the inlet/water valve, yes.
**To remedy this you will need to check and possibly replace the valve, not surprising for Bosch unfortunately**
This is what to look for..i.e.
As long as your model number is indeed correct, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus
Jan 27, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My bosch dishwasher is not filling up with water. Where is the inlet filter?
Welcome to FixYa.
Based on your description, " my bosch dishwasher is not filling up with water. Where is the inlet filter? "... and to answer your question, the issue is likely with the inlet/water valve.
**To remedy this you will need to replace the valve, not surprising for Bosch unfortunately**
As long as your model number is indeed SHU8805 series, this info below will be accurate.
i.e.
and
Regards,
Macmarkus :)
Nov 24, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Letter F appears on screen, and dishwasher does not start. Sounds like pump runs for a bit then stops. Door is closed. What is wrong?.
Hi
Error code F indicates that dishwasher control has detected a fault with dishwasher filling. This is due to faulty water inlet valve. Please check for clogged water inlet valve. Water inlet valve part#35
You can buy it from this link---
Bosch SHU531 water inlet valve
Hope this helps... Please post back if you need more information
Daniel
Nov 10, 2010 | Bosch SHU5315UC Dishwasher
Not getting water into machine although mains water is reaching hose intake. model number of bosch is sgs44e28eu05 type si1501b
There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. thanks.
Feb 17, 2010 | Bosch Dishwashers
Bosch SHU 4000 series dishwasher; Water keeps on filling
The inlet valve will be at the dishwasher end of the (hot) water inlet line. On this dishwasher I ~believe~ the inlet valve is near the rear of the unit. That means that you will need to pull the dishwasher out to get to it. Remove power from the dishwasher as soon as you can before messing with the unit.
Just past the connection of the supply hose and the connection on the dishwasher, there will be the valve (a solenoid valve with two wires coming out of it.) That is the little beast that has most likely failed.
Good Luck!
Jan 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
236 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Gabe Gilsrud
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
