Question about Canon PowerShot G7 Digital Camera
Canon Powershot G7 digital camera
After connecting my camera to computer with the cables plugged into USB port, I get a message stating cannot detect camera - camera is busy or unplugged - try again, or words to that effect. I was once able to download pictures but can't any longer. Help!
A friend suggested I uninstall the digital camera solution disk and then reinstall it. I did so and although my computer seemed to crash once it was restarted after turning it off and back on and getting a blue screen from microsoft stating I had to start it manually everything worked out. I am so thankful. I got about 100 pictures downloaded and stored into the appropriate album. Thank you for your concern.
Posted on Jul 11, 2008
I can't download pictures to my computer error message says cannot detect camera
It may be a USB port issue or a USB cable issue. Try an alternate cable or a different USB port. Try other USB devices on those same ports to make sure they work. Try using a USB card reader to transfer photos from the card directly instead of plugging in your camera directly.
Jul 04, 2012 | Canon Powershot Sx150 Is 14.1 Mp Digital...
I have a Canon PowerShot G9 camera. When i plug it into usb cord to dowload pictures, i get the error message "Communication Error" across the viewing screen of the camera.
The problem I believe is the sequence or flow of the connection.
With the camera turned off. Connect the USB cable to a computer USB port and the other end to the camera digital port turn the camera on by using the "Playback" button here is a diagram
Place diagram here
You know there is an easier and better way of transferring picture files and that's by using a memory card reader. A memory card reader plugs into the USB port of a computer and the camera memory card is inserted into the reader slot. The computer then looks at this as an external Hard Drive. Both methods will need you to format the memory card after the images have been downloaded to the computer. Formatting the memory card in the camera in which it is to be used will clean the card and making it compatible with the camera both the camera and memory card can then communicate without errors.
Jan 16, 2011 | Canon PowerShot G9 Digital Camera
I can't connect my Ixus 200 is canera to my computer ( XP 3 ), this has worked before. The camera isn't detected by any USB port. The USB ports work fine with other devices. I've also tried to connect to 2...
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Nov 20, 2010 | Canon PowerShot SD980 IS / Digital IXUS...
My canon powershot g7 USB quit working, tried different cable and different computer
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 08, 2010 | Canon PowerShot G7 Digital Camera
Computer not recognizing my camera when connected
Most of the issues can be solved by either reinstalling the software or by disconnecting and reconnecting the device.
In this case we can close in on three solutions
1) The USB drive in the system is not functioning. Try connecting any other USB devices to the same USB port and check whether it works or not. If the other device works well then it could be a problem with the data cable or with the port in the camera (usually firewire)
2) The data cable used to transfer data might have become faulty.Try using another data cable if possible and still the same issue continues then try connecting another camera to the system and if the other camera gets detected then the problem must be with the camera.
3) Try connecting the same camera to another system and see whether the camera gets detected. If no, then the port in the camera is defective.
After this we can close in on which could be faulty. data cable / Computer / Camera.
Feb 25, 2009 | Canon PowerShot SD1000 Digital Camera
Downloading digital pictures to the computer
Try next to locate the problem:
1. Connect other equipment to the same USB port on your PC to see if it works, if it is OK
2. Replace the cable
If that don't help, the problem is probably in the camera.
Jul 17, 2008 | Canon PowerShot A510 Digital Camera
Canon zoombrowser Ex downloading problem
The sd1000 manual says that you will get this error when you have too many pictures on your memory card (aprox 1000). I am not sure how many I had on my 2GB card but it was a lot. I deleted about 50 - 100 pictures and then it started working again and the new pictures downloaded to the computer.
Jun 28, 2008 | Canon PowerShot SD1000 Digital Camera
Try updating the Zoombrowser software.
If you have a connection to the camera, go into my computer and get images directly off the camera using scanner and camera wizard, microsoft's default program. This will at least allow you to transfer your images until you can resolve the software problem.
If you have no connection to the camera via your computer, you need to try some other troubleshooting steps to get a connection. I will post those below in the next post.
May 30, 2008 | Canon PowerShot G7 Digital Camera
Where is port to connect USB cable?
I'm sorry you're having trouble with this. I have put together a picture that shows where the mini-USB plug is supposed to be attached to the camera. I hope it helps. This picture actually shows plugging the AV cable into the receptical, but right behind it is the mini-USB port. This is where you connect the USB cable. It looks like you have to lift the flap on the corner to reveal the plugs.
Nov 24, 2007 | Canon PowerShot SD1000 Digital Camera
Canon sd600 trouble downloading images to computer
Did you checked that your existing camera's drivers are supported the Win Xp OS ?
Jun 24, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot G7 Digital Camera Logo
123 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
