Question about Polaroid TDA-03211C 32 in. LCD HDTV
The picture is to close how do you fix it - Polaroid TDA-03211C 32 in. LCD HDTV
    Master:
  • 691 Answers
Use the aspect button or ratio or size or go to the menu and change there.
Posted on Jan 04, 2011
I am a nail technician. I'm trying to make an album of some of my best work but when i take pictures of my clients' hands it comes out blurred. I need to take pictures of their nails up close to get all...
The closer you zoom the more sensative your camera becomes, I suggest you to use a tripod and take your pictures in a well lit area. You can also use the timer feature on the camera along with the tripod, this way you are not touching the camera when the picture is taken, this will reduce the blurryness on your pictures.
Mar 18, 2011 | Olympus X920 Digital Camera
My canon PowerShot SD750 digital camera screen suddenly turn black(dark ), I can not take picture because there is no image shown on screen. I still can record sound on video,but no image. what is going...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A.
Dec 26, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My camera will no longer show an image on the screen when i am trying to take a picture, and my pictures are coming out completely black. it is not the display button, what else can it be?
Very easy to fix for your camera. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Recommend Fix 5A by flicking as described in the link with your fingertip.
Dec 22, 2010 | Canon PowerShot SD1000 Digital Camera
When i turn the camera on and switch to picture mode the screen is completely black, and if i take a picture, the picture turns out completely black
Recommend Fix 5A in the link, by gently flicking with your fingertip as described in the article.
My pictures and screen are blurry...but when i zoom in my pictures come out clear...what can I do myself to fix it?
Your camera is likely set for MACRO, a mode for shooting pictures of things that are very close (close up shots).
For the pics that you have already taken, you might try using The GIMP or Photoshop to "Unblur" the image.
Jun 13, 2010 | Samsung S860 Digital Camera
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
I first experienced a problem with my Canon S2Is camera when it was only taking pictures of blank images. I found a "fix" recommendation which seems to have gotten rid of the black image problem. However,...
Think you need to do the fix more. Believe your shutter was previously stuck in the closed position. Now it sounds like it is stuck in the open position. Again keep trying the fix to loosen it up. Just to confirm, the "fix" you're talking about is taking repeated photos in shutter priority mode with 15 second exposures, and opening and closing the battery door while the shutter is opening, right? You may want to add some tapping of the camera against its padded usb cover in an attempt to get the shutter to jar closed.
Sep 13, 2009 | Canon PowerShot S2 IS Digital Camera
My VistaQuest VQ DV800HD camcorder's close up pictures are blury.
What's your definition of "close up"?
Sorry to say its a very cheap camera. It will not focus on anything under 3 feet. It's called a fixed focal camera. Anything beyond 3 feet should be fine.
Sep 06, 2009 | VistaQuest Video Cameras
How to fix canon ixus 7o lens error restart camera?
Do you mean its taking black pictures? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 05, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Black LCD screen on canon powershot S5 IS
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Aug 11, 2008 | Canon PowerShot S2 IS Digital Camera
Polaroid TDA-03211C 32 in. LCD HDTV Logo
47 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
