Question about Kyocera CS-2550 Black and White Copier
Unable to "Scan to PC" for anybody else, but me!
I am able to scan to my pc which has an ip of 10.0.0.92, but I can't configure any other pc.
Does each computer have to have file utility running? I already installed it on another & added a folder in his list, but it still won't scan.
On the folder # in file utility - does it have to match the # for the destination pc? If so, I already did this too.
This is the confusing part:
The destination List (PC) asks for:
• Name - User2
• Registration Number - 003
• PC address - 10.0.0.35
• Save number - 001
File Utility asks for:
• Folder # - 001 - does this need to match "Save #" or "Registration #"?
• Folder address - "C:\Scans"
Any help would be appreciated.
G
  • steel123 Jul 09, 2008
    I noticed that it has something to do with the "Registration Name"...
    • I went in and changed my name by one letter both on the Destination List and Sender List and sending scans to my PC no longer worked.
    • I changed my name back on both lists and it worked again!
    What does the Registration Name need to match on the network? Exchange username/PC User, ???
  • steel123 Jul 10, 2008
    I finally got them all working!!! As it turns out the problem computers had the windows firewall blocking the incoming scans. Thanks for your help!
    Sniper:
  • 54 Answers
The Save number and the Registration Number must match, folder # will be same as save and registration number.
Posted on Jul 09, 2008
  • Bryan Luther Jul 09, 2008
    needs to match nothing, this is just the name that shows up in the common book for scanning. When you changed it on the webpage, it probabaly did not keep the original registration number, it changed that back to 001.
  • Bryan Luther Jul 10, 2008
    if the save number when you register it on website is the same as yours set up in your scan to pc destination list, then the copier is trying to scan to the save number which is your PC not the user 2 pc. The way it should be is:
    • Name - User2
    • Save number - 003
    Then is Scanner file utility:
    No. 003
    Folder: C:\Scans
    System Connection Program: PDF Keyword Embedder
Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
My internet provider changed and with it came new IP addresses. Now my scanner on the Ricoh Aficio 2035 esp will not scan into the "scan folder" on my PC's desk top. How do I configure the...
Hi, If it is a network copier then it may happens. There will be a button that provide you all information about the copier by pressing it. You will find the IP Address of the copier in this information page. Disconnect the copier from system and print the information page by pressing the button. Then connect it again. Open internet explorer put the Present IP address in address space. Then put the new IP address in the configuration page of the copier in internet explorer. Reboot the system and the copier.
Sep 07, 2011 | Ricoh Aficio 2035 Copier
Sorry my scaner not working but printer will be working please tell me whats wrong
  1. The firewall must allow the following traffic.
    • TCP on ports 9400 and 9401
    • UDP on port 6000
  2. Make sure Scan Manager is configured for the correct IP address of the printer. If Scan Manager will not launch from SmartPanel and it does not show up in Control Panel, check <WindowsDirectory>\twain_32\Samsung. Without Scan Manager installed the printer will not be able to scan to PC.
To use Scan Manager you will need to have installed and configured the following items:
  • Installed the Print Driver, including the Smart Panel application
  • Installed the Scan Driver, including the Scan Manager application
  • Have an active connection between the Printer and PC
Important: If you don't have these items in place, stop now and perform the installation.
To scan to the PC using Scan Manager, follow these steps:
  1. Right click Smart Panel in the task bar, and then select Scan Manager. (Scan Manager Admin dialog appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=bdbe6a5u2kt1@namo.co.kr&sep=%7c
  1. Select the Printer you want to use, and then click Quick Scan. (Quick Scan dialog appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=pdq8czuzqk7f@namo.co.kr&sep=%7c
  1. Once the Quick Scan dialog appears set the following parameters:
    • Save Location - To change the default location click the Folder Icon to Browse for Folder.
    • File Name - The default file name is the date and time the scan is performed. To change the File Name, select the File Name field.
    • File Format - The file type selected will be the default file type for each consecutive scan. Select from the following formats. (TIFF, PDF, BMP, and JPG)
    namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=q0imt82cnhs9@namo.co.kr&sep=%7c
  1. After entering the previous information, click OK. (Scan Manager appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=1oy6sc87xa6m@namo.co.kr&sep=%7c
  1. Click Scan to scan the document to the PC.
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=45q4kejs8a31@namo.co.kr&sep=%7c
For additional information about Scan Managers' features and settings, click the question mark icon (?) at the top of the application window.
Dec 23, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Laserjet CM2320fxi & Windows Server 2003
Firstly if you are to scan to a "shared folder" on server, have you configured the access rights for the shared folder? Depends on how you want it, you may want create a User "LaserJet" in AD and use this account for all scans.
You should be able to do more configuration using it's IP Address web interface.
May 27, 2009 | Computers & Internet
MY HP WIRELESS OFFICE JET MODEL #J6480 ALL IN ONE PRINTER WILL NOT SCAN. ATTEMPTING TO DO SO RESULTS IN A POP-UP WINDOW WHICH READS "NO HP DEVICES HAVE BEEN DETECTED>" I HAVE ANHP TOUCH SMART PC RUNNING...
Here is one simple thing to try (not guaranteed but it fixes the problem sometimes):
  • Turn off your OfficeJet
  • Shutdown your PC
  • Turn on your OfficeJet
  • Turn on your PC
  • Try scanning
The reason this this works some of the time is that the software has an incorrect IP address for the OfficeJet.
You might also need to configure your firewall to allow scanning. Try the above first and see if it helps.
If this does not fix the problem, as a temporary work around, there is a way to scan using the web browser on your PC (e.g., Internet Explorer) and type in the IP address of your OfficeJet, which you can get from the front panel of the OfficeJet. You will see an option to scan.
Craig
Although I am an HP employee, I am speaking for myself and not for HP.
Jan 16, 2009 | Office Equipment & Supplies
Setup scan to pc function
Find the scanner on the network... you can use a tool like Advanced IP Scanner to search the subnet and then just hunt down the IP that belongs to the device -- it may not have a name registered.  Visit each potential IP via browser (http://192.168.1.50), one will show you the Kyocera web page.  The device has two, one for printer, one for scanner.. each one on its own IP....
That's how far I've got with mine - i was hoping it supports SMB scanning, but it may not.  So now I am looking for the rest of the setup.
Dec 08, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Scan to pc
yes needs to be running pdms communications utility, if thured toat software is installed then make sure that firewalls or antivirus is configured to allow the connection
Feb 01, 2008 | Panasonic Workio DP-2310 All-In-One Laser...
Scanner will not connect to PC
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Dec 28, 2007 | Kyocera CS-2550 Black and White Copier
Kyocera CS-2550 Black and White Copier Logo
2,483 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
