Question about Kenmore 15212 Mechanical Sewing Machine
When attempting to sew a buttonhole, my machine sews the first half perfectly, then the second half (on the right) poorly, with a straight type stitch instead of the zigzag stitch. The needle is dipping into the fabric properly as I watch it, but the stitches aren't being placed. Any chance you know what I should do to fix this? I have sewn buttonholes before and never had this problem.
    Genius:
  • 1,788 Answers
Is this a new machine? Even if it isn't, I would take it into Sears sewing machine department and have them try and figure this dilemma out. It won't cost you anything, because, don't forget, you are a potential new machine customer. And if it is a new machine have them give you a new one. I tried seeing if this problem happens in another brand to see if they have an answer for it but no one shows that particular problem. Good luck
Posted on Jan 04, 2011
Is it necessary to use the buttonhole attachment or should I be able to use the stitch selection buttonhole function? I have a Singer Advance 7422 model & our Singer store closed no help here.
You don't have to use the buttonhole attachment. Many older machines never had the buttonhole attachment but still made buttonholes. There are manual ways to sew buttonholes on a sewing machine with only a straight stitch and zig-zag stitch.
How to sew buttonhole with an old machine
Jun 20, 2017 | Sewing Machines
Where is the buttonhole stitch?
when in doubt read your manual .
search for one thru Google make,model,manual
Jul 12, 2016 | Sewing Machines
Can I sew buttonholes on a 5525?
If your machine has a straight-stitch and zig-zag function, you can always sew buttonholes. It would be helpful if your machine has the ability to set the needle left-center-right, but a buttonhole can still be done even without this function. Whether or not your machine has a programmed buttonhole function will be included in the owner's manual.
How to Sew Button hole tutorial
Just practice on scrap fabric before trying it on your garment.
Feb 19, 2016 | Sewing Machines
Buttonhole stitch problem
Try setting it to for a longer/shorter stitch length, as the case may be.
Mar 21, 2015 | Sewing Machines
My New Home HF-1012 buttonhole stitches don't work.
Take it back... and have him fix it again... this time ask him to tell you exactly what he did to get it to work.
Aug 29, 2012 | New Home HF-1012 Mechanical Sewing Machine
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Jul 16, 2011 | Sewing Machines
Machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Apr 16, 2009 | Sewing Machines
Buttonholing - Bernina 950 (semi-industrial)
This sewing machine looks exactly like the Berninas that I own, although my are not industrial. You just use the dial to make each side of the buttonhole, only having to set the stitch length to super small. The way you make buttonholes is this:
Think of the buttonhole as a square-ish capital O, with the center of the bottom of the O as the point where the button shank will lie when buttoned. Place the marked buttonhole area under the buttonhole foot, with this bottom point directly under the foot, squarely in the center of the 'hole'.
-Turn the dial to 1 and the long left edge will sew in zig zag stitches; stop the machine at the top of the O.
-Then turn the dial to 2 and the top edge of the O will sew; stop the machine after half a dozen stitches.
-Turn the dial to 3 and the right edge will sew; stop the machine at the bottom of the O.
-Turn the dial to 4 and the bottom edge of the O will sew; stop the machine after half a doze stitches.
-Turn the dial to 5 and run half a dozen stitches; this is a line of straight stitches that will 'tie off' the buttonhole.
Try this with a plain piece of fabric. Just put the fabric under the foot and dial away. You'll see how the stitches stitch.
I'll send a copy of instructions from my manual to you if you want. Email me at: pink8006@yahoo.com.
Sep 05, 2008 | Bernina 2500DCET
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Kenmore 15212 Mechanical Sewing Machine Logo
93 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
