Question about Sport & Outdoor - Others
I installed everything as per the instructions. Day one it all worked good, except at high speed. Day 2 all i get is water temp and no display. Checked all cables, re-mounted transducer level per instructions but still no depth or bottom. I suspect the transducer has packed it in already! I have not changed the factory default settings.
  • tim2559 Jan 04, 2011
    Hummingbird Piranhamax 190C. Transducer position has not changed.
    President:
  • 1,168 Answers
Hello Tim.
Not sure what make your sounder is but I suppose it really does not matter at this point.
If indeed it was working and not hit on anything to knock it out of place there isn't much else it could be.
You are getting a temperature signal so that indicates that the connector is still plugged in OK.
Not an uncommon issue to have the transducer go bad. I have had to replace a few over the years.
Have you a fishing buddy with the same make you could hook up to and try it?
Can you contact the manufacturer to see about warranty?
I use Lowrance and they have a tech line to call if you need assistance. Perhaps you could look up your manufacturer and see if they also have one.
Thank you for using FixYa.
KL
Posted on Jan 04, 2011
  • FUBAR Jan 04, 2011
    Humminbird has a support section on their website. While i have not used Humminbird products personally we do install them in boats for our customers.
    I do believe they do have good support. They would have to to keep customers happy.
    It certainly would be a good place to begin to fix your sounder.
    http://store.humminbird.com/products/307...
Is there a recommended amount of water that should be drunk by a 60 year old male per day.Is it the same if Robinson orange squash added?
the amount of water for people is between 11/2 to 2 litres per day However that will depend on the temperature and the body movements
for example on a cold day but with a strenuous work out , the water intake still has to be high
on a cold day rugged up the intake will be less
On a hot day it has to be high and if there is strenuous work happening even more than the 2 litres
As the body uses electrolytes those electrolytes become depleted with the water intake so rehydrating fluids are required as well
any added flavouring helps with the taste of water but it is the quantity that is important
body waste water color is the test for hydration --straw to dark tan or brown indicates insufficient water intake ( blood from the dry kidneys) light color to almost clear indicate s good water intake
Oct 17, 2017 | Orange Pool & Spa
How to return temp set to programme norm
PDF]Washing Machine - Samsung
www.samsung.com/us/pdf/wf218_manual.pdf
Samsung Electronicsto read this manual to take full advantage of your Washer's many benefits and ...Warnings and Important Safety Instructions in this manual do not cover all possible conditions and ..... per hose and install each fill hose to the water valve. ... Press the button repeatedly to cycle through the different water temperature options.
[PDF]User Manual - Indesit
Jan 16, 2016 | Washing Machines
Intex purespa displays current water temp but will not turn on or start filter/bubbles. Bought 1 mo ago: just set it up a week ago. Was working fine for 1 week. TrI'd unplug and reset. Any ideas??
is displayed temp less than 2 degrees than setpoint temperature ? its possible this situation will disallow the pump to go to high speed and the air infusers to work till spa heats back up , or can be a heater fault as well
Aug 15, 2015 | Intex Pool & Spa
Engine overheat and no heat
Maybe your radiator is clogged.
Mar 12, 2017 | 2001 Nissan Sentra
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
First My sister inlaw has a 3/4 recirc line. used the by pass h&c under last faucet to use cold as recircu line. Note acutal 3/4recirc is in kitchen but even thou closer to water htr. it is last for...
I don't understand everything being asked, so add a comment any time.
Problem1 is excessive electric bill.
Suspect is new 120Volt Taco recirculation pump.
Look at motor nameplate for amps and watts and HP. Taco pump is usually robust 1/3 HP which is 252 watts or same as running four 60 watt light bulbs.
If pump runs 18 hours per day x 252 watts = 4536 watts or 4.5 Kilowatts per day
Buy a kill-o-watt meter that plugs into outlet, and plug Taco pump into the meter for 48 hours.
This will give you total watts used for that time period.
1000 watts = 1 kilowatt.
Electric bill is probably 12 to 20 cents per kilowatt.
So if Taco uses 4.5 kilowatts per day, that is $.54 to $.90 per day multiplied by 30 days.
So cost is $15 to $30 per month.
Problem2 is Taco runs too long.
Taco operates either by thermostat or by timer. You choose which mode by using slide switch that is usually located under the timer dial. Set switch to TIMER to use timer, and ON to use thermostat, and off to turn TACO off.
If Taco is set for thermostatic operation, the Taco might be defective. Or there could be crossover problem at single handled faucet.
Another problem could be air in the water line: install air vent.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/How-to-set-timers.html
Jul 17, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Model #SD-20-2N11CC WATERWAY PUMP (2HP) - Trying to find out how many gallons per minutes pumped on high & low speeds
Rule of thumb for a 2 HP pump using a 2 inch pipe is between 60 and 80 gallons per minute. Factors affecting flow rate is the distance between the pump and the pool, how many bends and turns and of course the condition of the filter. If you need to meet a specific turn-over rate, use the lower number to determine in the event you sould be called on the carpet.
Low speed? I am sorry. I don't know the rule of thumb on this.
You could install a flow meter, available at your professional pool supply. They are easy to install and not a lot of money. Follow the installation instructions as best as you can.
Incidently, comercially speaking, the 'turn over rate' should be around 8 hours for a public pool. Your jurisdiction may have other standards. Commercial pools should run 24 hours a day at that rate during the open season. Turn over rate means all the gallons of the pool should go through the filter in 8 hours, or all the gallons should go through the filter three times per day. Example: 16000 gallons of water in the pool, your filter and pump should be pumping 2000 gallons per hour. Studies show that it actually takes up to 5 days to get every actual 'chunk' of water to go through the filter, so, many of the 'chunks' of water go through the filter multiple times per hour. BTW, I use the word "chunks" in an effort to better paint a mental picture of what is happening. I am not suggesting your water has "chunks" in it.
Thanks for your question @ FixYa.com
Jul 07, 2011 | Waterway 2hp Hi - Flo 2 Speed Above Ground...
I am assumimg that when the plastic peg is pushed down the recirculater for the hot water is off. When up, it is on. The Build set the timer and no manual was left. Hot water comes onwhen it should be...
Do you have the auto-circ recirculation pump with timer?
If so, here is manual for that specific product:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/Auto-circ-manual.pdf
Manual gives instructions for a different timer dial than timer than shows on unit, so they must come with different dials.
Instructions say pegs pulled out = timer on
Conversely, pegs pushed in = timer off
You might be able to hear the pump operating to see if these instructions are correct for your recirculation timer. The kids would love a listening assignment under the sink.
To see images showing how recirculation system operates:
Setting times:
Try 1/2 hour ON in morning and 1/2 hour ON in evening. Warm water will stay in pipe for a while.
Recirculation system with timer costs $10-17 per year to operate, assuming timer runs 1 hour per day with electric prices at 10 cents per kilowatt hour. Operation cost is straight line ... so if timer runs 2 hours per day, cost is $20-34 per year at 10 cents per Kwh.
Water saved might equal 5 gallons per day, or 1825 gallons per year depending on usage. Average water wasted waiting for hot water is 1/2- 2/3 gallon depending on length of pipe. Set a bucket under spigot to test your home when circulation system is not ON.
Cost of water depends on local billing rate. The municipality saves purifying water, pumping water to your home, and finally pumping and processing sewage drainwater.
If you are on a water well, the pump electricity from saving 2000 gallons a year is a dollar or two per year since water well generally consumes less than 1Kwh per day for ordinary house.
Sep 29, 2010 | Hardware & Accessories
1997 cadillac eldorado running hot
Make sure you put in the correct temp thermostat. GM usually has 2. A low temp and a high temp. Most shops will give ya the high temp just because thats usually what the book calls for. you might want to try a low temp. Also, sometimes, when a car runs hot and everything has been repaired....well, almost everything......it might be the head gaskets. And those my friend are no easy task. But..somewhere to start. have your cooling system pressure tested. Only way to really know for sure. Oh..also make sure your fan is working!!!! You might have a faulty fan switch.
Jun 19, 2009 | 1997 Cadillac Eldorado
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Sport & Outdoor - Others Logo
42 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
