Question about Numark ttUSB Turntable
Software says if I continue, it will record in mono. How do I switch to stereo? I'm recording from an album to my computer, and onto a CD-R.
  • Numark Master
  • 5,056 Answers
Maybe the software is only detecting one channel. Try checking your connections. Don't forget the wires to the cartridge.
Posted on Jan 05, 2011
I can now play my albums through my computer but I can't record/rip them onto my computer. No opportunity...not seeing any options. What can i do?
Have you any software to record them? If you can hear them a software package will record them. I use Magix Audio Cleaning Lab. This will also remove the scratches and noise and make MP3's of the recordings.
Jan 13, 2013 | Audio Players & Recorders
CAN I RECORD FROM A VHS ONTO A CD OR DVD WITH MY STEREO?
In short, NO. Stereos are for playing not recording.
If your stereo has a DVD recorder and a video/audio input then you should be able to use it. I dont know of many stand alone "stereos" that do this. In general, stereos only deal with audio, but newer stereos and receivers can handle video as well, but usually are just PLAYERS not RECORDERS.
If not, then you will need to connect your VHS to a stand alone DVD recorder. You could also connect your VHS to a computer with the proper adapters (USB, firewire, etc) and software, and then record the VHS video to the computer. Afterwards you can then make a CD or DVD of the video.
A stand alone DVD recorder is much easier.
Mar 06, 2011 | Televison & Video
Maybe stupid question....is it possible to record 8 separate mono tracks on this thing? I cannot seem to select only track 5, 6, 7, or 8. When I try to record onto 5, for example, it is impossible to not...
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
Aug 30, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Im gettin only one side when i record a vocal wit mixcraft 3
Make sure your recording onto a Mono track in your software, don't choose stereo when creating the track.
Feb 20, 2010 | Samson C01U USB Condenser Microphone...
Can I use this machine (telex copyette 123)to cancel old cassettes by copying a blank cassette onto three cassettes??
You should be able to do that with it, but note that this is a mono copying machine rather than stereo, so it may not entirely write over the existing recording if it is in stereo and the heads are in a slightly different position, but that would be the same for a stereo recorder too.
I think it will work, but really for decent recordings, I wouldn't recommend 'recycling' tapes in this way, they deteriorate fairly quickly.
Aug 10, 2009 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
Recording vs880ex - can't hear the headphones in stereo
what you do is treat her like a lady wants to be treated.
touch it
when you input make sure your only putting one device in the hole.
kiss it after your done
Are you recording in mono?
That could be the problem
Jul 21, 2009 | Computers & Internet
Recording in mono and not stereo
Thanks for your rapid response. Fortunately I discovered the problem and was able to resolve it. Whether it is just my computer or all computers I wouldn't know. When I switched my computer off, after recording vinyl to my pc, then switched it back on again my pc had reset the default input so I had to reconfigure it again. Since then I have not used it but wonder if I have to reconfigure the recording device everytime that I switch my computer on. I did make the USB Codec microphone my default recording device and applied the setting but the pc seemed to do its own thing.
All the best
Paul Watson
Dec 28, 2008 | ION Audio TTUSB10 Turntable
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
Tascam DP-02 cd player...
You cannot rip a CD directly into the DP-02 using the unit's CD drive.
Your choices for doing what you want are:
1.) Rip the CD into .wav files onto your PC using ripper of your choice. Then you'll have to edit the resulting .wav file using a program like 'Audacity' (which is a free one) and convert the stereo wav files into 2 mono wav files. You'll have to save the mono files with dos 8.3 filenames and then import them into the DP02 using the instructions for importing wav files in the manual. To preserve the stereo, import each mono wav file to a separate adjacent track on the DP02 and then pan one left and one right.
2.) You could play the CD on a stereo and connect the stereo outs to the two inputs on the DP02 to record the CD track. You'll need patch cords which are RCA (mini phono 1/8" jack) to regular phono (1/4") to do this.
Cheers,
bd.
Nov 09, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Oct 20, 2008 | Tascam 2488 Portastudio Multitrack...
Numark ttUSB Turntable Logo
78 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
