Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
My dishwasher will not fill, and sounds like it is still trying to empty.
    President:
  • Hotpoint Master
  • 2,118 Answers
Most likely you have a bad water valve on the dishwasher,sediment gets in the valve or the solenoid is bad on the valve.also you can disconnect the water line going to the dishwasher and then open the valve under the sink to make sure it's not a problem with the house water but most likely it's the water valve on the dishwasher.next time send the model number and i can look up your machine and give you the part number
Posted on Jan 03, 2011
  • Sal DeAngelo Jan 11, 2011
    also check the flood cone or float,if it's stuck up it will do this
My dishwasher does not fill or empty?
wont fill
sounds like the water intake solenoid
wont pump out
could be timer control board
water pump /solenoid
Nov 10, 2016 | Dishwashers
My dishwasher leaves sand like residue in my glass cups. I have tried running it empty and with vinegar, it still does it, how do I stop this from happening?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Apr 02, 2011 | GE Dishwashers
Dishes are not coming clean. The detergent basket is not emptying out, after cycle has run, the detgergent is still partically in the dispencer
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Jan 24, 2011 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Dishwasher won't empty
sounds like the hose is blocked (usually with broken glass, followed by larger food particles) that runs from the dishwasher to the sink. You may need to remove this piece to check. If that isn't the problem, it's probably electrical.
Jan 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Empties and fills but boils the water
Can you hear/see any washing sound/spray, it sounds to me like the wash pump could be faulty.
Nov 20, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Fills and then empties and error 1
sounds like the new PCB is not connected to all of the sensors (the water fill sensor especially) either that or you have got a faulty PCB.
Oct 01, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
101 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
