Question about Philips DVP642 DVD Player
The power light is blinking with no other activity
    Guru:
  • 91 Answers
Here is the solution. This is a common problem with this player.
Common DVP 642 problem (only problem with a great player): They die,
and you have a blinking red power button.
This is actually surprisingly easy to fix. It's really easier than I
make it look, but I'm just being really clear in case anyone reading
this has never seen a soldering iron before. Here are the steps I did
(and note that, if you're still under warranty, this will void your
warranty). The decision to try this is up to your own discretion
and may be a last ditch effort before throwing the player away.
Short version: Check the board to see if capacitor C316 is bulging. If
so, get a 1000u capacitor >=16V and replace it.
Long version:
1. Unplug everything
2. Unscrew the side and rear screws to remove the top cover.
3. On the board where the power cable goes in, look for a capacitor
(looks like a little drum with a '+' on the
top) that is bulging upward either a little or a lot. It may be
leaking some brown fluid as well.
4. I'm betting that the writing on the board at this location says
'C316'. If you google 'dvp642' and 'c316', you'll get hundreds of hits...
5. If that's the case, you'll need to find a capacitor and a soldering
iron. Visit radio shack or similar electronics
place and buy an elecrolytic capacitor that says 1000u (the 'u' is
actually a lower case greek 'mu') with a
voltage greater than or equal to 16v (this is not calculated: it's
simply what others have reported success with.
I couldn't find one and used a 35V one instead). You should be able to
find one that looks somewhat similar to
the damaged one (it might be a little bigger or smaller, but you'll
want the same basic shape). This should cost less than $2.
6. Borrow or buy a cheap soldering iron and some solder. I borrowed
one from a friend at work...this is NOT
my area of expertise, so don't worry about the difficulty!
7. Now the tricky part: back on your DVD player, you need to get that
board out. Unplug the two cables
connecting to the board we're working on, unscrew the screws holding
it down, and, using some pliers, hold
down the wings of the little plastic piece that is still holding the
board down and slide the board up. I flipped
this around to get at the bottom while leaving the power cord in
place.
8. Heat up the soldering iron. Locate the spot on the bottom of the
board where the C316 capacitor is attached.
Remove your new capacitor from the package. There should be one
shorter leg which is the negative side. It
will likely be marked this way as well.
9. One side of the capacitor should have a ' -' on it. Note which side
this is. You may not be able to see it until it
is removed, so be aware of needing to know this as you remove it.
10. After it is warm enough to melt solder, lay the soldering iron
across the joints you identified as belonging to
C316. Tug gently on C316 as you do this and it should soon come free.
This is a little tricky to hold the iron,
the board, and the capacitor all at once, so please don't burn
yourself! Again, note which side is negative and
which hole it came from. This is the negative hole, and the other is
positive. There will likely be some solder
left over around each hole. Just try not to let it run between the two
holes or you will short out the connection.
11. Grab your new capacitor and line up the longer leg with the
positive hole. Lay the soldering iron against
that hole on the other side and push the leg through. Line up the
negative leg/hole and repeat. Lay the iron
across both to heat up enough to push the capacitor legs through and
the capacitor down to the board.
12. Check the connections for each leg. There should be a small *****
of solder joining each leg to the metal
of the board, but not running to any other point of the board. If it's
run to some other points, you'll need to do
some searching to see how to clean up it up a little bit as I'm not an
expert at this. If you need a little more
solder, lay the iron across the joint for a few seconds, then feed
your solder into the hot spot until a small
amount flows over the joint. Remove the iron, wait a moment, then
remove the solder. Look at the other
solder joints on the board for a rough idea of how it should look.
13. Use some wire cutters to trim the legs down to the solder.
14. Pop the board back over the plastic piece and reconnect the cables.
15. At this point, you're on your own. Personally, I made sure I
wasn't touching any metal and plugged it in.
Since I didn't blow any fuses and the player seemed to work, I
unplugged it, reassembled it, and went to watch a movie.
Posted on Jan 03, 2011
  • Bogdan Kedzierski Dec 27, 2012
    Jake, Thanks a lot. For $1.80 I managed to fix my DVD. In RadioShack I got 1000uF 35V physically much bigger but still it fit. The job was done in 1 hr, including a short trip to the store.
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Other lights blinking but internet light is blinking for 2-3 times them off all the time so I am not getting internet
On most DSL modems, normal light states are:
Power - Solid
DSL - Solid
Internet - Solid or flashing quickly when data is being transferred.
Ethernet - Only on and flashing quickly if cable attached to it and an active device
Wifi - Solid or flashing with active data transfer
Sep 24, 2014 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Is my modem is blinking is this normale
The POWER light should be 100% on.
The WIRELESS light should blink -- hunting for wireless devices, and communicating with them.
The NETWORK ight should blink when there is activity to/from the internet.
May 17, 2014 | D-Link DSL 200 (DSL-200) Modem
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
No picture, No sound. Green power light on DTA50 digital transport adapter blinking 2 quick blinks, stops, then 2 quick blinks, etc.
You may have to call your cable company to re-activate the DTA50. I have Comcast and once i a while I had to re-activate it.
Does it do the same with other cable outlet?
Dec 04, 2010 | Televison & Video
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
Recieve and Send lights blinking
Are you unable to connect? The send and rcv lights should be blinking. Make sure that your link light is on and not blinking. Your link light is your connection to your ISP
Feb 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Constantly blinking Activity light
Well, you are very correct with the activity light blinking and the increased blinking except the fact that modem will encounter a problem in future...
The 5 different lights on your modem namely Power, Ethernet, DSL, Internet and Activity have their own indications and explanations.
1. The Activity Light indicates the amount of activity that is takin place on the computer on the Internet though the activity might blink even when you are not browsing. This can be explained by stating that the computer constantly keep sending signals  about it being connected to the internet and any other acknowledgements..
So, you've got nothing worry about unless the Power or the Ethernet or the DSL or the Internet light Blinks....
Cause they are the resultants of a fried modem(check for the adapter), faulty LAN connections, interrupted Dsl line and the account verification failure indications respectively.....
Dec 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Receive activity and send lights are blinking. power light is on. and online is off
try to unplug it and the cable for a few minutes, then replug it and see if that helps.
Jul 27, 2008 | Arris SURFboard SB4200 Modem
Receive, send, and activity lights are all blinking but online light is off
Power Cycle the modem if the 4 lights do not go solid you would want to contact your cable provider to ensure signal is being received properly to modem.
Philips DVP642 DVD Player Logo
988 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
