Question about Dryers
What is the Cu Ft. capacity of a Whirlpool dryer, Model number LEN2000KQ1?
Illeagle
  • 525 Answers
SOURCE: Our dryer, described below, takes
Your complaint is:"Our dryer, described below, takes between 4 and 6 hours to dry, though it's advertised as "heavy duty" and "extra large capacity.""
White Kenmore 5.8 cu. ft. Super Capacity Gas Dryer
Sears item# 02690412000 Mfr. model# 90412
Based on the information provided above, I am unable to provide a positive solution to your issue. Your model number is incomplete! I have provided some common solutions to help guide you in your search. This information is for a non-specific brand model, gas dryer.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these:
Vent
Flame sensor/gas valve
Internal ductwork
Cycling thermostat
Lint Filter Vent: Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Also note that, to maximize drying efficiency, the vent should be as short as possible.
Flame sensor or gas valve coils: This is the most likely cause. Click links below. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3449&PPStack=1 http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3229&PPStack=1 There's a flame sensor near the igniter. If it's defective, the gas may shut off prematurely. Another common problem occurs when one of the electrical coils on the gas valve fails intermittently. If this happens, the flame shuts off before the thermostat sends a signal, which can greatly prolong the drying time. If the sensor or the coils are causing the flame to shut off, replace them.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 14, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer capacity
Yes, a full size dryer as yours is easily capable of drying a full sized load from the washer you mentioned. The wash tubs in the new model washers and dryers still maintain a standard size. For example, the front loader dryer that I purchased to match my front loader washer is completely identical to earlier standard models without all the fancy packaging. I could have saved some money and purchased only the washer, but...the wife needed a matching pair.
Now, you will still have to properly sort items to ensure they dry efficiently. A copy of your dryer owner's manual will describe this to you. I'm not here to give you lessons in how to dry your clothes, but if you do not own a copy of your manual and would like to refer to it, you can obtain a copy at geappliances.com. Just look under the "Service and Support" section for "Use and Care Manuals". Just type in your model number and your owner's manual is availble in a downloadable .pdf format.
The point I'm attempting to make here is that although you can place a full load from your washer in the dryer, if you do not properly separate certain items, they will not dry properly. I did not want you to think this was a cause of the appliance.
In addition, make sure the dryer vent ducting is properly cleaned and not clogged anywhere. This can also contribute to longer dry times.
I know you were only asking a simple question. I just wanted to be thorough in case additional question may arise. I hope this information is helpful to you.
Posted on Nov 14, 2008
  • 77 Answers
SOURCE: Whirlpool 6.5 cu ft 5 cycle is not timing and drying clothes qui
First I would check to make sure your vent is not clogged or kinked. As far as the timer, the only fix would be to replace it. Unless of course you have the feature that detects the dryness and that would put you back at the venting problem. Good luck.
Posted on Apr 18, 2009
BadtzMaru
  • 4 Answers
SOURCE: What year was the whirlpool dryer made? Series # LEN2000KQ1
You'll need to call Whirlpool for an official answer. Mine was manufactured in the first half of 2002.
Posted on Oct 26, 2009
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Posted on Jan 01, 2010
Need to know how many cubic feet my frig is so I can compare when shopping for another.
This is the information I could find.
Refrigerator Type Side-by-Side Total Capacity Cu. Ft. 21.7 Cu. Ft. Refrigerator Capacity Cu. Ft. 14.40 Cu. Ft. Freezer Capacity Cu. Ft. 7.30 Cu. Ft. Energy StarĀ® Qualified Yes
for more information try this link.
Whirlpool Appliances for the Home Kitchen and Laundry Room
Bob
Mar 16, 2015 | Whirlpool Refrigerators
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Sep 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Need to know the year model of a whirlpool washer & dryer that belonged to my mom? The dryer Model #LER6848AWO and the washer Model #LSR7233BWO?
Mar 2009 dryer model #LER6848AWO serial and the washer model is Aug 2010 ... Model Number: LSR7233BWO. Hope you find this useful.
Apr 19, 2011 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
On my whirlpool dryer, it says " Control Panel Locked". Is there a reset on this thing. it was working fine and then this message popped up. HELP,
You don't give a model number, is this applicable? Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Jan 03, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Dec 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Sm8525079 what is the capacity of this washer and what is the capacity of the matching dryer?
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryers Logo
117 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
