Question about Sony BDVE770W Theater System
I have the Sony BDVE770W Theater System and I have it connected to my DLP TV which does not support audio return channel. I connected a Digital Optical Audio Cable from the TV to the BDVE770W unit but am not getting any TV sound through it, only from the TV speakers. I made sure that the Digital Optical Audio Cable was selected from the menu of the BDVE770W, but I get no sound (and yes I tried turning the volume all the way up). I have component cables connected from my Wii and I get surround sound from that when I select the component port from the menu, but nothing from the Digital Optical Audio Cable. Any ideas?
  • 2 more comments
  • WebKill Jan 04, 2011
    It's antenna, so the antenna is connecting to the TV, that is the only source.
    The source is an antenna, so there is nothing else to connect to. I would use the audio return channel over HDMI, but the TV doesn't support it. I'm wondering if the digital cable is bad.
    It's a Samsung 42 inch DLP, abotu 5 years old, I think it's HL-R4266W. I have looked in teh sound options, but didn't see anything that I thought would make sense for this.
  • WebKill Jan 05, 2011
    That seems perfect, but I got home and don't have those menu options, it appears my model number is HL-S4266W. I did, however, mess with the settings a bit and got it working. Thanks!
    Brigadier General:
  • 8,546 Answers
Try sourcing your TV audio from whatever source IT is watching, usually the cable box.
Posted on Jan 04, 2011
  • David Dunn
    David Dunn Jan 04, 2011
    Ok, so let's look at the TV and make sure IT is configured to send sound out. What make and model? There is usually a menu for sound.
  • David Dunn
    David Dunn Jan 05, 2011
    The manual:
    http://www.retrevo.com/support/Samsung-H...
    For starters choose the Standard Mode on page 73.
    I would recommend the following:
    Auto Volume OFF
    Digital Sound Format (Page 77): Dolby Digital ON (NOT PCM)
    Internal Mute ON: turns the TV's speakers OFF so they won't compete with your other ones.
    You should see some indication at your HTS should light up something indsicating a good digi8tal audio input. last thing to check or try would be the optical cable for seating and no small-radious bends or kinks in it.
Connect HT-CT260
in the menu you need to set the audio sauce,, analog . digital ect
Apr 19, 2013 | Sony HT-CT260 - 2.1-channel sound bar...
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
Hook up everything right,but can't seem to get suround sound from TV. Went to Bestbuy and brought a Digetal Optical cable and it still dosen't seem to give mr that sound like the home theater sound---help!
On the remote press the surround mode button and set it to Prologic movies or music when you are watching TV to get the rear speakers to work.
Or if you have Digital cable TV with Dolby Digital 5.1 content, make sure you have connected theLG to your TV using HDMI v1.3a. There is an audio return channel on this cable which will stream 5.1 audio signal to the LG system.
Mar 11, 2011 | LG LHB975 Theater System
I have a Sony DBVE770W and cannot seem to get sound from my Dish Network receiver through an optical digital audio cable. The instructions for both devices basically say to just plug it in and it should...
Have you selected the correct input on the television? Also double checking the connections would be a good idea. If you need to determine if the port is bad try connecting the optical cable to another device or input, if you still cannot get anything you'll know if it's a bad cable or bad port.
Daniel Busa
DISH Network Customer Service
Feb 23, 2011 | Sony BDVE770W Theater System
HOW CAN I HEAR SURROUND SOUND FROM MY SONY EX500 55'' REGULAR TV CHANNELS AND XBOX 360
there is usualy an out put on the back of you tv that will say Moniter out plug in the red and white to them and and to your surround sound,
Feb 11, 2011 | Sony BDVE770W Theater System
I have a Panasonic Model TC-p42X1 TV hooked up to a Panasonic SC-PT480 Home Theater system by an HDMI cable from HDMI 1 on TV to HDMI on Theater unit. System setup test okay for speaker sound connections...
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Feb 03, 2011 | Panasonic SCPT480 Theater System
I just purchased a Sony BDV E770W home theatre system and there are 2 problems that I need help solving. I have a 30GB iPod Classic which I am trying to play through my home theatre system, but when I...
Hey there - did you ever get a solution to this problem? I'm having the exact same problem with my iPod Classic (60gb). I've tried using Sony's online tech support, but to no avail.
Dec 16, 2010 | Sony BDVE770W Theater System
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Sony BDVE770W Theater System Logo
431 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
