Question about Kenmore 2303x Top Load Washer
My washing machine sounds like a freight train even when running empty. i leveled it and it still does the same thing.
5 Suggested Answers
aeccone
  • 5 Answers
SOURCE: I push the start button, water runs for 3 secs, machine cuts off.
IT SEEMS LIKE YOUR TRANMISSION IS GOING OUT
Posted on Apr 09, 2009
rylee_smith
  • 8619 Answers
SOURCE: ul code about 10 to 15 seconds into spin cycle
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Calypso 21082
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Posted on Sep 21, 2010
Macmarkus
  • 2605 Answers
SOURCE: We have an asko 10504 front loader washing
Welcome to FixYa.
Have you checked the pump to insure the filter isn't clogged or debris causing the noise ? Or do you know where it is and how to check it ?
In the event the washer can't drain sufficiently it will not spin properly either. This is by design, but it's easy to confirm or dismiss.
Check as follows...
**Unplug the unit from the dryer or the wall which ever scenario applies to your set-up, or turn off the breaker at the home service panel...safety first**
Remove the lower panel with two screws and then you'll see the pump filter/insert as shown here...
Once here, twist the filter out ( make sure you've got some towels, a wet/dry shop-vac or a drain in the floor close by as there WILL be water present ) and check the filter, pump, and hoses to the pump, drain etc. thoroughly for debris.
The filter should look like this...
Let me know if any of this isn't clear and I'll attempt to help you move forward. Once you've cleared the pump filter or ruled out it was indeed blocked or not, you can now try a short spin/drain cycle to listen for whether the noise is still present.
Let me know how you make out. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided for you here today at FixYa.
Regards,
Macmarkus :)
Posted on Dec 11, 2010
My washer sounds like a freight train, I have been finding pieces of plastic in with the closth
I dont know whether you have secured the dryer to stop it from moving if it shakes about you need to secure it and make sure it is level(eg the floor is level or the dryer is level and all the leg screws are down and even so it doesn't wobble about.
The more the dryer wobbles about the drum inside will wobble inside the casing and it will break the things that hold the drum in place ,sound like that has already happened.but secure it in place and see what happens.
Jun 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer very loud on spin cycle
I know the exact sound you are hearing, I had the same thing several yrs ago on my old Whirlpool. I think it was something with the transmission, but what I needed was no longer available. I found a lot of info by entering the make/model nr in search box at appliancepartspros.com. You could also look atR44U61 RepairClinic.com
May 02, 2017 | Maytag Washing Machines
The washing machine does not spin, it says error 4
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Shane
Mar 08, 2011 | Washing Machines
Sounds like a freight train when it spins
Hi from retired Englishman in SW France
It is necessary to start with ensuring the machine is stable- it sounds as if yours might not be. Out of balance is a common problem with both front and top loaders!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning but I've not had any feedback of this nature.
Good luck,
John C
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When the washer spin it has a load noise, it sounds like a plane is comming down. I have a duet sport whirlpool washer
the bearing probably went bad, thats the sound it makes, may even sound like a freight train at times.
Feb 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
During the lest spin cycle ,the drum spins like its out of balance, with bad knock , viberation. even after making sure the load is balanced in the drum. even without a load or water, (empty) it still...
The machine sounds as if it might be unsteady. If it only happens on the spin it is probably slight. Try levelling it at the feet, using a spirit level helps enormously to get it level.
Dec 09, 2010 | Washing Machines
The wash liquid does not empty after the wash is finished
hi, it sound like your waste outletis obstructed or the pump is not working, to empty the machine pull the easte pipe out of the stand pipe ,get a bowl, keep the pipe above the level of the drum! slowly lower pipe into bowl the water should run from the machine to stop the flow lift the pipe above the drum level, continue until machine empty! if the MACHINE EMPTIES THIS WAY THERE WILL NOT BE A BLOCKAGE AND YOU SHOULD CHANGE THE PUMP, hope this helps you
Nov 11, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing machine
I have a piece of **** duet washing machine. It suddenly stopped spinning. I knew this because the tell tale sound of a freight train in my laundry room wasn't there. I did take off the back and notice the belt was off of the pulley in the back. I got dirty, but I fixed the belt. It does spin now. Try the belt!
If I could only figure out why it it SO loud!
Nov 10, 2008 | LG Washing Machines
Kenmore 2303x Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
