Question about Lexmark X5150 All-In-One InkJet Printer
My printer will not work on my computer, it keeps asking for me to put the disk to program the printer and I don't have one, because the printer was given to my family.
    Genius:
  • 1,087 Answers
You can visit the Lexmark website to download the Lexmark X5150 driver for free. Click on this link Lexmark X5150 Drivers. Select your operating system by clicking on change OS.
Then click on FILTER.
Click on the Complete Driver under Recommended downloads. Download, execute the file and follow the instructions on the software. NOTE: Use Vista driver in Windows 7. Lexmark X5150 is not supported on Mac 10.4, 10.5 and 10.6.
Posted on Jan 10, 2011
I put in the install disc and at the start it says that it wont install 100% cause of Memory only 893MB (recom 1000MB), I don't understand cause the computer Memory 1024MB, what am I missing? Plea
Its don't Ask for your RAM (Read Only Memory), but it's require Hard Disk memory... so please check free space in your Hard disk... if its less than 1000mb then free some space........
Sep 01, 2012 | Lexmark X2670 All-In-One Printer
My computer keeps restarting. whenever i turn the computer on it asks me if i want to start normally, safe mode, or last known working configuration. No matter what i choose, it restarts anyway. How c
Run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 12, 2012 | IBM ThinkPad R52 Notebook
Im wanting to remove some of my arcsoft programs that i do not use which ones can i remove without affecting the basic program?
First, make sure you have the Arcsoft disk in case you change your mind. I remember seeing the Arcsoft programs several years ago, they came with some printer I bought. If you have your Arcsoft disk, then you are free to experiment with options.
Look under Add/Remove Programs, and see how many entries you see for Arcsoft. There may just be one, I don't really know. But if there are several, then try to make intelligent choices about what you remove and what you keep. I'm not sure what you're using this for - - - anyhow, it says "Cards and Calendars", so those are the 2 main functions. Maybe if you're not using Calendars, you could remove that.
But I have a hunch it's probably just a single suite with these 2 functions built in. Let me know if this helps.
BTW, if you don't have your Arcsoft disk, I would not recommend uninstalling ANY part of the suite. For example, if it came pre-loaded on your computer, the only way to get it back may be to do a total, "factory reinstall" where you format the hard drive and put everything back the way it was when you bought it.
Thanks ~Jim :-)
Jul 22, 2011 | Arcsoft Print Creations - Cards &...
Thyer printer that has printed letters 'till last Sunday, today didn't respond to any commands. today. I disconnected the printer's power cables.Disconnected and reconnected the USB cable.The...
The firewall is a protection the computer has..and usually blocks some devices or programs to connect to the internet or function ...It is used to mainly protect the computer against the external intruders ...To check if the printer is firewalled ..you have to go into control panel from the start menu..and in there double click the firewall icon ..and on the exceptions ..check the list and see if the printer is ticked...if it is not..tick the case and click ok ...
But ..my advice is to reinstall the printer's driver from scratch ..and after that see if it works...usually when the printer seam to lit up ..and work ..but do not answer to the commands from the computer ..the driver is corrupted and causes the issue ..
To reinstall it clean ..you have to go back in the control panel ...open the add remove programs..and remove the old program for the printer..(you will find it on the list by the printer's name ...there can be more than one program associated with the printer if it is a multifunctional ..)
after that ,,,insert the disk that came with the printer..and run all programs on i t...and follo w the instructions on screen ...At one moment you will be asked to connect the printer..and continue the installation until finish ...or ..you install all programs and after that connect the printer and restart the computer ...Im almost sure that this will fix the issue if the printer do not have a physical damage ..
Have a nice day , and ask for guidance if something causes you misunderstandings ...
Jul 07, 2011 | Lexmark Z645 InkJet Photo Printer
Need instillation disk/proper software download for a LexMarkZ35
All you need is the printer driver:
Download it then install it.
You can get it from here:
http://www.siliconguide.com/drivers/device/469/
and by the way, what kind of file is your daughter's project?
If its just documents, you can use any word processing program like MS Word and Open Office to print it.
Feb 28, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
All in one printer x1240
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Nov 02, 2008 | Lexmark X1240 All-In-One InkJet Printer
Installing printer to new computer
i do not have disk for my lexmark z611
Aug 19, 2008 | Lexmark Z611 InkJet Photo Printer
I have a X6100 series and trying to download my printer to my new computer Acer which has Microsoft Vista program and I keep getting stuck. Do you have a solution so I can download properly.
I had to close out of my Norton security completely. Reload my Lexmark disk and run the program. Then put back on my Niorton Security program again.
May 27, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
206 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
