Question about Philips Magnavox 20MC4306 20" TV/VCR/DVD
I have 20MC4306. Recently when you turn it off it turns itself back on. Also when you turn it on shuts off after 2 seconds. Tried putting in a video vhs then press play and wait few seconds and hit stop. TV stays on most of the time. After trying different outlets, holding plug and was going to plug it in a surge protector the other day when it turns itself on without being plugged in. Ghosts????
    Guru:
  • 91 Answers
Sometimes when the TV recives a brodcast signal for a new update to the mainframes firmware, it will have to turn itself on to install/recive the update and aslong as it is connected to a power source it can do this. hope this helped answer your question. Have a good day :)
Posted on Jan 03, 2011
My phone keeps shutting down and turning back on
Sounds like a battery issue - does it charge correctly when plugged in?
Aug 05, 2014 | Apple iPhone 3G
1998 grand marquis turns off by itself while running.
If you think the problem is the security system. This is for programming with no keys.
Use a scan tool to verify that the numkeys pid value is less than 8.
Use a scan tool to verify that the sparekey pid value is enable or yes.
Insert either the remaing key or a new cut key and turn to run.
Use the sacan tool to navigate to pats system and then choose security access. The scan will count to 10 minutes before the model will allow you in, once in, choose ignition key codes erase.
Did connect scan tool and turn key off. Inset key and turn to run for 3 seconds, then turn the key off and remove. Insert second second key and turn to run for three seconds, then turn key to off and remove.
Apr 05, 2017 | 1998 Mercury Grand Marquis
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Biostar gf7100 mp - wont boot with ext usb drive attached
Hi, What you have to do is shut down the machine, pull the CMOS battery(CR2032) out and out and put your jumper on pins 1-2 from 2-3. Wait 30 seconds and put the battery back in. After installing the battery, put your jumper back to pins 2-3 from 1-2. This should work.
Jul 07, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
I have a 1992 dodge spirit and it wont turn over and i just drove it to work and when i came back out i tried to turn it on but then it shut off and i tried putting gas in the carberator but then it turned...
If it starts & runs for a few seconds with gas down carb, obviously you have a fuel delivery problem, as in fuel filter plugged, fuel pump, or perhaps you got some bad gas recently?
Jun 16, 2009 | 1992 Dodge Spirit
Intel® Server Board SE7501CW2
Might be the prolem with your SMPS not providing proper o/p voltage, change SMPS it will works
Mar 20, 2009 | Mercury Electronics KT266A Motherboard
PS3 Turns Itself off and wont turn on
sorry mate i cant fix it but my buddy has a problem with his also
his ps3 freezes even in the menu screen and during video chat it shuts off
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Dell Inspiron 1100 shuts itself off right after powering it on
if i take out the ram it does not shut off it is a problem with the ram
Mar 06, 2008 | Toshiba P25-S670 Notebook
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Power issue, blank screen.
Don't listen to dnbull. i looked at the PSP sites, and apperantly that kind of thing will only happen if it got screwed because you shut of power while it was loading, downloading, saving etc. and it will take about 2-4 hours of time for the data to restart. Put in on a charger and leave it on for a long time and it should restart. you might not have all your files though... sorry...:(
May 25, 2007 | Sony PlayStation Portable (PSP) Console
Philips Magnavox 20MC4306 20" TV/VCR/DVD Logo
120 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
