Question about Acer Aspire 5050-3242 Notebook
Charging Can you tell me how I can charge my laptop as the pin has come out with the power charging cable.
  • 244 Answers
No, you can't, you have to replace/repair your power port.
Posted on Jul 09, 2008
PLT7223G power pin broken
Try charging it with the USB cable from the computer. It could be your charger pin is faulty. This happens from frequent in and out charging. The pins on the charger tip get worn out. If it charges with the USB cable then get a new charger.Charging from the computer is slower but it works.
Mar 03, 2014 | Proscan PLT7223G-K 7in Android 4GB Tablet...
Acer aspire 5735 takes a charge but wont power on
Check memory sticks (one at a time in different slots)
Remove battery, and power cable. Keep power button pressed for 5 min then insert only power cable and try to turn on
Mar 21, 2013 | Acer Aspire 5735 Notebook
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
My Aspire 5520-5043 began showing trouble to start: no power ligh
thats mean the charging system is faulty and sometimes there are breakages at the edge of the power cable where the pin is.try another power cable if it shows the same signal then the fault is on the laptop board.
Aug 02, 2010 | Acer Computers & Internet
Dc jack broke. tech guy replaced but now none of my 3 power bricks will charge the battery. they all give power to run laptop but do not charge battery. when boot up get error message saying I connected an...
It is possible that it could be a bad solder joint. It could also be that the connector is a different one. Some laptops use a dual voltage power structure. On the Inspiron E1505 (same as the 6400) I have it requires the dual voltage power. This is where the outside of the plug is the ground and the inside of the plug is one voltage and the center pin is yet another voltage. In this case, (if I remember correctly) the inside of the plug is like 19.5 volts and the center pin is like 9 volts. The inside of the plug supplies the power to the laptop and charging circuit and the center pin tells the laptop that the power adapter is plugged in and should start charging. If the laptop recognizes the Vostro power supply then this is a good possibility. Either way, it is worth getting it checked out. The last thing you want to do is burn out the charge circuit on the motherboard by having the incorrect power supply plugged in to it. It may work for a while or it may work forever but you never know.
Dec 24, 2009 | Dell Inspiron 6400 Notebook
Charger is no longer working
Oh, believe it or not. My computer use to do the same thing all the time. Just take the prongs on the plugin and bend them outwards slowly. This will make a tighter fit in the outlet.
Jun 11, 2009 | Acer Aspire 7720-4428 Notebook PC
What signal is sent over the center pin of the power adapter?
the problem isn't in the psu - it's in the laptop. The centre pin supplies a trigger voltage with a simple carrier which tell s the BIOS about the power characteristics of the unit. Missing that signal, the BIOS assumes that even though there may be enough power to run the laptop, there may not be enough to charge the battery - a situation that, on lower power PSUs, can lead to damage to PSU and/or laptop. That's a safety feature that it doesn't attempt to trigger the charging circuit. The most likely reason for that trigger being missing is the (very poorly-designed) PSU interface having become disconnected from the rail. The socket needs replacing.
Dec 04, 2008 | Computers & Internet
Power connection trouble
It sounds as if the power pin (where the AC cord connects to the computer) has become unsoldered. To fix it usually runs $100-200. Because the connector pin is so fragile, the damage to the pin is caused by the day to day tugging and pulling on the power cord.
What you needed when you got the computer is a cable stay or cable retention device like the Jerkstopper. It takes up the strain when you yank or tug the power cord and minimizes the damage to the power pin. It's a very common problem with laptops.
Here's a short video that talks about the problem. . . .
May 29, 2008 | LG X-Note LM50 Notebook
Charging Problem
go back to old bios if u can
Jan 21, 2008 | Dell Latitude D600 Notebook
Acer Aspire 5050-3242 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
