Question about Kirby G6 Bagged Upright Vacuum
Wont **** properly. is just moving dirt around. i have a G6 i unclogged it changed the bag. dont know what else to do.
  • 694 Answers
With a Kirby that's around 10 years old, there's a good possibilty the fan is worn or broken. You can purchase one online (http://www.elikirbyclub.com/category_93/Kirby-GSix-Fan.htm for $17.55 plus shipping and handling) or at a Kirby store.
Instructions for replacing the impeller can be found at the following site.
http://www.ehow.com/how_5534689_replace-fan-kirby-vacuum-cleaner.html
Posted on Jan 04, 2011
My Kirby is not picking up correctly, almost just seems to move fibers around.oves fibers, dirt around .Brush is engaged, green light is on. Any idea what's going on?
look for a blockage in the head elbow of the suction pipe or in the pipe itself
check foe air leaks that lessen the vacuum
Feb 15, 2016 | Kirby Vacuums
Kirby G6 not vacuuming
The dirt path probably is clogged. The brushes are not turning because the drive belt is disconnected/broken/stretched
Sep 23, 2012 | Kirby G6 Bagged Upright Vacuum
The kirby wont start no power
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
Jun 20, 2010 | Kirby G6 Bagged Upright Vacuum
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Swivel glide has no suction in the hose but seems to have a bit at the head, definatly not alot. can i fix this myself somehow?
Get ahold of a plumbers snake, disconnect the hose and run it through unclogging it .
Undo hose and see if there is suction right at the socket where the hose plugs into to see if there is suction there.
Inside the place where the bag goes, at the bottom there is a motor dust filter, see if it is clogged.
Also at the beatter brush, make sure that there is not dirt crammed around the nozles input, and check to see if the belt is not slipping on the beatter bar and remove the wound threads from the beatter bar it self.
Best!
Robert!
Oct 02, 2009 | Dirt Devil SwivelGlide Bagged Upright...
Eureka 4463 Vacuum blows OUT dirt
sounds like the pipe is stopped up,, you need to take it off and run a rod through it and unclog it,, sometimes small toys ect. can get in pipe stop ot up,, hope this help you,,good luck
Aug 14, 2009 | Eureka Lite 4463 Bagged Upright Vacuum
Cleaning a drain using kirby
first can it pick up water if so you put take the hose on suction and wrapp a rag around the end so you get full suction in the drain and turn it on.if not hook the hose up so it blows instead of sucks,do the same thing with a rag around the end of the hose and seal the hose in the drain,then turn it on.if you have a shop vac that will work better
Apr 27, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Sep 17, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
115 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
