Question about Garden
I have a Murray Performance Tiller Powered by 6.0HP quantuum. Model FT600X82A. It will start and run at full choke. However, the carburator continue to flood. Gas will drain even when not running. What is my solution?
  • 173 Answers
You can try and clean and rebuild carb or replace it with a new one.
Posted on Jan 04, 2011
Why Tiller cranks but will not run when you need it to till?
If you don't have a manual, could can read/download it at this link.
If the engine stalls under load, the mixture may be too lean. There should be a mixture screw on the carburetor. Note its position, and turn it counter-clockwise 1/8 of a turn to see if there is any improvement in engine performance. Repeat this but don't exceed about a half turn.
The tank has a vent and this should be kept vertical under the cylinder cover in the small "pocket" in the cylinder cover.
Lack of power can be caused by a dirty air filter or blocked muffler screen.
See the article below for troubleshooting 2-cycle engines
String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
May 30, 2014 | Mantis 2-Cycle Tiller
14" CRT 3.5 hp tiller,
Make sure your Air cleaner is not obstructed. Clean it!
Check your spark plug for the proper gap. Adjust your
LOW speed throttle screw. It may not be getting enough fuel flow. Check your fuel filter screen (Inside your gas tank). Good Luck
Sep 19, 2017 | Craftsman Garden
Starts but doesnt run
Is the choke on?
Is the fuel tank full?
It sounds like a fuel problem, if the tank is full and the choke is not on, then I would check for dirt in the carburator.
Aug 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
Runs only with the choke more than halfway closed
adjust the carburator, it is running to lean.
Jun 17, 2009 | Mantis 2-Cycle Tiller
Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
Jun 08, 2009 | Mantis Tiller
Must use full choke position to keep it running.
I would say the carb. needs to be taken apart and the little ports blown out with air.
Also ,check the tank for dirt.
Apr 24, 2009 | Briggs & Stratton Garden
Cannot keep tiller running
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
Please rate. Thanks jj505
Mar 28, 2009 | Garden
Garden Logo
250 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
