Question about Cycling
How do u replace the cable ? i can,t get it to thread
    Brigadier General:
  • 8,546 Answers
Which cable? Look it up at http://www.parktool.com/blog/repair-help
Posted on Jan 04, 2011
How do I tighten the hood release cable
some cables cannot be tightened up - due to the way they are made for a particular car. sometimes you need to replace them.
if this is the case. acquire a cable sleeve clamp, locate the cable inside the engine bay, (somewhere easy to work) cut the cable and thread one end of one cable through sleeve and crimp one side, thread through other end and pull on cable end until cable is tight enough for you and crimp the other side.
Mar 28, 2015 | Cars & Trucks
How do i Reconnect the speedo cable on my 1978 GMC Truck with 350 motor, 4x4?
Depending on which end needs to be reattached, At the Speedometer Head or at the Transfer Case, or at the Cruise Control Module (if equipped with Cruise Control).
At the Transfer Case : Underneath the truck, on the left side of the transfer case, near the tail housing/rear of the transfer case (if it's a NP203 or NP205), there should be a small rectangular box threaded onto the transfer case, the other end (facing away from the transfer case) has a threaded end on it where you'll thread the end of the speedometer cable on.
At the Speedometer : Behind the instrument cluster, protruding from the back of the speedometer, is a round male port that the speedometer cable snaps onto. You just push it onto the back of the speedometer and it locks into place. Some cables have a metal end for the Speedometer end, some have a plastic end. The ones with the plastic end will sometimes break and won't stay locked in place at the speedometer.
If it's equipped with Cruise Control, you'll have 2 Speedometer Cables, an Upper Cable (From the Cruise Control Module to the Speedometer) and a Lower Cable (from the Transfer Case to the Cruise Control Module.) Both ends of the Lower Cable have Female Threaded ends (one to thread onto the box on the side of the transfer case, one to thread onto the Cruise Control). The Upper Cable has one threaded end and one Clip On/Press On end. Reconnecting the cable is the same as the methods I mentioned above, but with 2 additional threaded connections on to the Cruise Control Module (which is usually found on the Fenderwell in the engine compartment)
Jan 09, 2015 | GMC Cars & Trucks
Transmission fluid seeping out of braided clutch cable at it' lowest point.
If you have transmission lubricant leaking from the cable, you need to replace the cable. The "braided" cable is probably an aftermarket product. I've never known H-D to offer a braided cable. There is a small seal in the end of the cable to keep the lubricant from running into the cable. There is also an o-ring around the threaded end on the cable to keep the lubricant from seeping out past the threads.
Good Luck
Steve
Sep 03, 2011 | Harley Davidson FLHRCI Road King Classic...
Replaced speedometer cable, new from nissan, goes up to 80-90 with just rolling in yard! Also, replaced power steering hydraulic hose, and still have leaks on gear box, and on right side of engine.
Check for a kink in the new cable. HAVE has several with that problem. ALSO check and make sure it is seated all the way . When you installed the new hose the hose is a compression seal. IF you tighten to much it will leak. Look and see if it is coming from the thread area or around hose. IF hose, to tight and you compressed the compression fitting, if threads... try to cover threads with Teflon tape.
Feb 20, 2011 | 1987 Nissan Pathfinder
Oil is coming out the clutch cable at adjusting threads what would cause this
Right where the threaded adjuster goes into the outer primary case, there's a locknut. There should be an O-ring on this treaded piece to seal in the oil. To replace the o-ring, you must go through the procedure to replace the clutch cable by removing the primary outer cover, disassembling the clutch release mechanism, and turning the cable out.
Good Luck
Steve
Aug 30, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Clutch cable leeks oil
The o-ring around the threaded end where it enters the transmission only keeps the oil from leaking to the outside. If you're getting oil on the inside of your cable, the cable needs replacing. The small oil seal is in the end of the threaded piece that screws into the transmission end cover.
Oct 19, 2009 | 2005 Harley Davidson FLHT - FLHTI Electra...
How to replace the speedo cable on a yamaha yzf 600 r
Thread new cable into place alongside old cable. As you remove tiedowns or clamps holding old cable place new cable in as you go. Undo bottom of cable at front wheel, replace with new cable. Do the same underneath speedometer and you are done.
Oct 05, 2009 | 2005 Yamaha YZF 600 R thunder cat
How to tighten the ebrake cable on a 1999 chevy cavalier
Before doing that adjustment check the rear brake shoes if they are worn replace them and you won't need to tighten the cable, if you must follow the cable up from the rear brakes to the spot where they come into one soak down the long threaded adjuster rod with liquid wrench then loosen the lock nut on the long threaded adjuster rod and turn the rod while holding the housing with pliers, after check ing play in lever lock the nut to the threaded rod and housing.
Jul 16, 2009 | 1999 Chevrolet Cavalier
Cannot figure out how cable threads through
This video may help
http://bicycletutor.com/grip-shift-cable/
May 23, 2009 | Cycling
Hanbrake cable
yes you can replace one prart of the break cable. but it aways best to replace both,the frist time. so you will be done with it . oko have a nice day
Mar 30, 2009 | 1998 Ford Escort
Cycling Logo
18 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
