Question about Kenmore Dryers
My dryer cuts off after about 10 min even thought it is set for 30
  • Kenmore Master
  • 8,220 Answers
Clean your dryer sensor bars off with windex. They might not be sensing moisture. my dryer cuts off after - themobilian_665.jpg
Posted on Jan 03, 2011
Samsung dryer dv328aew/xaa won't turn off
It seems to me that you have a defective relay in the main control board.
Oct 30, 2014 | Samsung DV328AEW Electric Dryers
AUTOMATIC HEAT SETTINGS NOT WORKING PROPERLY
lg's have a dry sensor that senses the wetness of the load they are not that reliable.. and will shut down the machine does it work on manual timer? meaning set it on high for 30 minutes.. it will probably run the 30 minutes... I have had this issue with my lg and so I just use the manual settings cheaper than having a 300$ service call. Its a problem with the dry sensor on the lining of the drum...
Dec 09, 2013 | LG DLE5977 Electric Dryer
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
Our dryer is not drying! I can see the reflection on the floor underneath the dryer of the heater--it stays on maybe 10 seconds then off then on again in about 10 min. What are your thoughts!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 09, 2010 | Kenmore 400 6943 Dryer
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Hello, my speakers hum for 10 to 30 seconds when i turn on my receiver. sometimes they do this even with sound coming from the system for up to 10 min. i tried changing the speakers. moving the power,...
i think ur unit deposits humidity . . try to clean it up with smooth paint brush over the boards and connectors . . better yet spray some contact cleaners i think this will do . . . otherwise resolder is needed . .
Feb 23, 2010 | Onkyo TX-SR304 Receiver
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Aquarious condenser dryer
hi there the problem you have there is a faulty start relay located behind the control panel accesed by removing lid.
part no for relay is C00095530
Dec 08, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
