Question about Dei 555x Lexus Key Transponder Bypass Module
I am a car alrm installer tech and i need to find the location of the immoblizer wire harness on a 2000 lexus gs300.i am installing a remote start and i need to install the dei 555x bypass mod to let the car start remotely.the clock wire should be black/white, and the data wire should be green/black the only wire plugs i found on the key houseing are a two wire plug with a brown wire and a green wire. there are about a hundred different plugs under the steering colum so i need help.
SOURCE: After changing my spark plugs and wires in a
On american cars the firing order is imprinted on the engine itself, if not the firing order is located in your owners manual it will also give u gap specs as well. Make sure the gap is right and firing order is right, If they are both correct then you might need look into your distributor or coil whichever ur case may be. If all this is correct, check and make sure ur wires aren't faulty and fouling out against metal or the brackets their mounted in. This is rare but it does happen sometimes.I hope i have helped you
Posted on Mar 16, 2009
  • 4 Answers
SOURCE: cig lighter fuse blew. renewed but cig lighter and remote key not
you probably didnt change the right fuse and had another one blown at the same time you also could have a primary fuse under the hood that blew. once fixed dont use pump again. not same amps drawn
Posted on May 06, 2009
  • 77932 Answers
SOURCE: I'm having trouble installing a radio in my 1992 toyota celica
go to any auto parts store and ask for a 12 volt test light, it has a bulb inside and a pointed end like an ice pick, u attach one end to a good ground and then probe wires for power, when u have a hot wire with 12 volts the light in the handle will shine on. They cost about $6.00 at Kragen I think.
Posted on May 12, 2009
  • 347 Answers
SOURCE: engine diagram for a 2000 toyota corolla
remove the spark plug wires one by one.. remember the connection from no. 1 spark plug to the distributor. the wire from the coil is connected to the center of the distributor.
Posted on Sep 18, 2009
  • 364 Answers
SOURCE: aftermarket stereo wiring harness does not fit oem
Theres a standard amongst most stereos, so if these colors apply, then you will be right,
Red is Ignition power
orange is direct power
Black is earth
blue is for phone
White is for electric arial
then there will be four coloured wires with matching color trace wires, these are the speaker wires.
Hope this gets you going, good luck.
Posted on Jan 01, 2010
Lexus gs300 drives fine wont go into reverse
Most likely the linkage isn't set properly on the transmission or worn out
Apr 28, 2015 | 2000 Lexus Gs 300
94 gs300
Check all of the battery terminals and cables and check the wires on the starter/selonoid, start from the battery and follow the cable out and check all conections , clean and tighten them and if it still does it the starter/selonoid is bad and needs replacement...
Sep 18, 2008 | 1994 Lexus GS 300
1994 lexus gs300
Could be a faulty injector. Or a problem with the wiring harness or the engine computer.
Aug 25, 2014 | 1994 Lexus GS 300
Where is the fuse box on a 1998 lexus gs300?
On this website you find fuse box diagram and description for Lexus GS300 (1998 - 2000)
Lexus GS300 1998 2000 fuse box diagram Auto Genius
Jun 02, 2014 | 1998 Lexus Gs 400
99 lexus gs 300 fuse box diagram
We do not have the owners manuals for any model of Lexus. they are not free to download, you must purchase them from Lexus/Toyota
Feb 24, 2012 | 1999 Lexus Gs 300
I had the Viper 5501 installed on my 2000 4Runner last week and today my new truck battery has died. I got it boosted and now it is dead again. The only thing I can think of is the car starter is draining...
Yes your alrm could have been installed wrong. Depending on where the tech hooked up his wiring he maybe at a spot where the alarm is not allowing the trucks computers to shut down. The trucks computers should shut down after 20 minutes to where it draws only 20 to 30 milliamps. If the tech hooked up his wiring in the wrong locations the computer may never shut down and will stay at 150 to 200 milliamp draw which in this case would drain the battery
Dec 24, 2010 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
Where on a 1999 Lexus GS300 is the Fuse box diagram
Nov 26, 2010 | Lexus GS 300 Cars & Trucks
93 Lexus GS300 knock sensor electrical wiring?
Knock sensors are small, metal objects that detect prignition be fore it happens and cut fuel to the motor for a split second the keep it from destroying itself. (very important on turbocharged cars=melted pistons can result)
The leads are attached to the engine harness. Unscrew your bad sensor, put some teflon tape or paste on your new sensor and install by hand, then tighten with the correct wrench. Plug in the harness plug.
Aug 31, 2009 | 1993 Lexus GS
2000 Chevy Astro Autostart installation
You can't disable it, you have to buy a bypass modual to bypass it during remote start, the wires are in the ignition harness I have them in stock if you need one
Sep 07, 2008 | 2000 Chevrolet Astro
Dei 555x  Lexus Key Transponder Bypass Module Logo
80 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
