Question about Polaroid TLX-02311B 23 in. LCD TV
Tv not turning on, i have checked the power cord and have 120volts going to the tv.
    Master:
  • 691 Answers
Power supply caps are bad probably, search you tube they have a video on how to fix, put in polariod repair or fixing
Posted on Jan 03, 2011
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
The TV (32" Dynex flat screen) will not turn on.
Hello, it does not power at all, means not eaven a power light blinks in the front of the TV, which also means there could be no power getting to the TV through the cheater cord, or a completely busted power supply due to shorted power regulators, lightning damage or surges in the power line. The easiest is to check the outlet, the power strip braker if you are using one, the power cord going to the TV. The rest of things would be inside the TV(power supply and power regs etc....)
Nov 06, 2010 | Dynex DX-L32-10A 32" LCD HDTV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
TV repeatedly turns off after 3-4 seconds
Disconnect all the cables from the TV including the power cord. Make sure that the power cord from the TV is not connected to a power surge protector.
Connect the power cord to the TV after few hours and turn it ON to check if it's working normally. Also, you may try resetting the TV to the original factory settings.
If the issue persists then the problem is related to the main power board and it's required to check and replace any burnt out capacitors.
Dec 01, 2009 | Insignia LCDTV26 26 in. Television
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
My problem is with my 1 1/2 year old Sylvania hdtv. I turned it off yesterday morning and it won't turn on. I have left unplugged overnight for the "factory settings" to go back into effect. I have...
Check the outlet to be sure you have power to it. Then check both ends of the tv power cord to insure that they are actually plugged in. good luck.
Jan 23, 2009 | Sylvania SRT2232S 32" TV
Is this set digital ready?
I'm sorry, but this tv is not digital. You might be able to use an inverter that converts 12volts DC to 120volts AC to power a digital converter box.
Nov 07, 2008 | Sansui COM312AD 13" TV/VCR Combo
Will not turn on
Requires surgery.
I have the fix.
Jul 22, 2008 | Astar LTV2001 Television
T.V. DO NOT TURN
There could be a problem in the main power supply or perhaps the standby power supply. To me at a guess i would say there is most likely a bad capacitor in the standby power supply or there is a problem in the switch mode power supply. if you have no electronic troubleshooting skills, play it safe and take the set into a repair shop or replace it. Now a days, a 32" TV set can be had for under 200bucks. Good Luck
Jun 13, 2007 | RCA F35731MB 35" TV
Polaroid TLX-02311B 23 in. LCD TV Logo
159 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
