Question about Dryers
I own a frigidaire dryer model number aeqb6400fs0 with an error code e9e 116. What does this mean
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
ngfam1
  • 639 Answers
SOURCE: pf error code on frigidaire gleq2152es
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Did you check the owners manual first to see about the blinking codes?
Usually the codes mean you just have to have factory service remedy the problem!!!!!!!!!!!!!!!
This is a situation that you will need service!
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
SOURCE: frigidaire affinity dryer problem
help[ my affinity dryer is somehow tearing /slashing rips in my clothes.
Posted on Sep 05, 2008
message "ad" showing on my affinity frigidaire, anything wrong with this?
Posted on Sep 27, 2008
  • 3 Answers
SOURCE: error code E9E
E9E stands for low voltage and/or intermittent power. At least that's what the "training" manual said.
However, my dryer was overheating to the point of the back being too hot to touch. The service rep with Best Buy told me the error message made no sense. Computers aren't so great. My dryers only three years old. My previous "analog" dryer ran forever.
Posted on Nov 16, 2008
Frigidaire dryer. What do the error codes e56 and e9e mean?
sounds like you need to consider a new dryer .
May 19, 2015 | Dryers
Frigidaire dryer error code e9e
Hello zabbster - Typically E9E means that there is an issue with the control board receiving low or intermittent voltage and you would need to contact a professional to verify the house wiring and confirm the power supply.
Sep 25, 2012 | Frigidaire Dryers
Model glgq2152es error code E9E
The E9E code is a low voltage/intermittent voltage alert. It says in the troubleshooting manual to press cancel when this appears.
You may want to check the plug or the wall socket to make sure there is not a short occuring. The fault code is not saying your dryer is broken, just to check for proper voltage.
Jan 10, 2010 | Washing Machines
I keep getting a E9E error code on my Fridgidaire gas dryer. It starts, then stops and flashes the code
this is a line voltage error code press the cancel button for three seconds check you power and make sure the power supplied is correct.
Sep 12, 2009 | Frigidaire Dryers
Dryer front load model # GLG22152ESO, Flashes Error Code E9E
Ok, i would also pull the blower assembly and, check it for clog's as well. clean out the entire exhaust hose as well. if this doesn't stop the shut down, you will need to replace the hi limit thermostat and (dryness)sensor(if equipped) as well.
Jun 09, 2009 | Frigidaire Dryers
Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 25, 2009 | Kenmore 67082 Electric Dryer
Dryer error
hi The codeE9E means theres a problem with the voltage going to the motor. this is a complicated one I would call a tech to look at the dryer, thanks
Jan 11, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My affinity frigidaire dryer keeps flashing an E9E error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Nov 26, 2008 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I get an E9E fault code on my two year old Frigidaire front loading dryer.
Sep 08, 2008 | Frigidaire Dryers
Frigidaire dryer
it sounds like the programer on the drying side has had its day
Dec 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dryers Logo
96 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
