Hello I have a whirlpool dryer Model# LE9380XTW0 Serial# MA4902371 Stock# LE9380T I set timer to 30 minutes after 20 minutes it stopped. The cloths were warm but when I tried to restart it, it made the noise which normally indicates the clothes in dryer are done. Now when I try to start dryer it will start for a split second then go to the buzzer.
Jimster
  • 240 Answers
SOURCE: kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Posted on Nov 18, 2007
IFIXALL
  • 868 Answers
SOURCE: HELP! My Whirlpool Thin Twin Dryer only works in Permanent Press sitting-buzzer goes off in all others
Replace the timer/control board
Posted on May 26, 2008
VOTIT
  • 2071 Answers
SOURCE: Whirlpool duet dryer
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or change.
To test the thermostats or fuse, set the multitestester to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
serve?bfmid=37924989&siteid=38910744&bfpid=1292788&bfmtype=standardClick Here to Order a Multitester from Ace Hardware
Hope this may help you;
DON'T FORGET TO RATE;
Posted on Sep 09, 2008
SOURCE: replacing spin belt whirlpool clothes washer
There is indeed a drive belt to the imperial 70. Problem more likely is in the 'wig-wag' unit that engages and disengages the spin clutch and the agitator drive
Posted on Sep 10, 2008
  • 67 Answers
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Posted on Oct 28, 2008
Whirlpool gas dryer Model#WGD4900XW1 worked on certain timer settings for 6 mos. Now it only works on one setting and turns off. One more note: you have to gently pull the timer knob for it to turn on
Hello David, We're sorry to hear about your concerns regarding your Dryer. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dryer. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 14, 2017 | Whirlpool Dryers
Whirlpool wed4815ew1. Timed Dry works, timer advances. Automatic Dry does not. Plenty of heat, clothes dry fine. Bought new timer W10185982 STILL doesn't advance
Hello David. We regret to hear about your Dryer not working on select cycles. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dryer. If that does not help then we can only recommend service. If you would like for us to schedule service for you, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 08, 2017 | Whirlpool Dryers
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
The dryer is not running full cycle
Hello Joann,
Thier is no model or brand listed in your question but if it has a timer and not a digital display it could be a simple as the dial that shows where the timer is set is broken so ya think your setting it for 40 minutes or what have ya but its actually being set for lets say 20 minutes...check teh dial,if its digital display and time is controlled by the computer let me know the brand and model number and i will think why its happening.
GENE
Nov 06, 2011 | Dryers
My whirlpool dryer wed9400sw2 is over a year old, but has stopped running. The last load was left damp. When I tried to restart the load, I pressed Power, Start. I hear a brief click from the start...
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 28, 2017 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Dryer Electric Model #LER2614EWO Serial # MF2511530. When you push the button to turn it on it won't turn on. You set the timer for 30 minutes, push the button and nothing happens. Can...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Whirlpool Dryers
I have a kenmore electric dryer. It dries for about 20 minutes then stops. If you wait for about 10 minutes and start it back up it continues to dry again.
Hello There,
1st- Check to see if your not running on overload with a clogged dryer hose the one that goes outside
2nd- your timer may be going bad or you have a bad sensor thats resetting itself.
Is this a newer model???? What year and model number?
Apr 02, 2009 | Whirlpool LER5636P Electric Dryer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
