Question about Kenmore Dryers
Drum wont turn on my kenmore dryer,model #96060100
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
If you hear the motor run, but the drum won't turn you need to replace the dryer belt. Here is a video to show you how.
Posted on Jan 03, 2011
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
My dryer wont work. my kenmore elite wont turn on. the light in the dryer is working so I know there is power to the unit but the control panel wont turn on. The model number is 110 60092991
Kenmore by Sears,
DD
This is really a simple project
I believe your belt broke and Kenmore put a kill switch to protect your motor and heating element.
there are two screws when you remove your lint screen.
Remove those screws.(philips)
With a straight screwdriver, gently pry up the top of dryer.
When loose, open all the way to the back and rest on the wall,
On each inside,behind the door, at the top, is a 1/4" bolt. Use Socket to Remove both. Pull up and out on the front and put it to the side.
Remove the drum.
Now you can clean the inside with a vacumn. See the kill switch in front of motor.
The model is inside the door on the left
since you have it apart check the drum rollers for flat spots as well as freedom in movement DO NOT GREASE
Put it back together
Jul 24, 2010 | Kenmore 63942 Dryer
My kenmore model 1107020290 will heat but the drum will not turn
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 07, 2010 | Dryers
My kenmore dryer's drum does not spins. I checked for the belt and it's fine. Where do you suggest I check?
the drive motor if its not turning then the drum wont turn, also if its sliped the belt off thats another reson why and one more thing to look at is how tight is the belt on the drum,,, is it just sliping round it? is the drum very tight to turn by hand? are the drum bearings jamed up, is any thing stuck behind the drum? ??? like one of the kid's?
i hope this is helpfull to you
Oct 23, 2009 | Kenmore 63942 Dryer
Dryer starts but wont stay on
There is a switch on the motor that activates when the drum is turning at the proper speed. This switch should be checked if the drum is turning properly.
Eric
Jun 14, 2009 | Kenmore Dryers
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
113 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
