Question about Peg Perego 12 Volt Rechargeable Battery
After charging the 12 volt battery the first time for 14 hour, how long after each use doe it need to be charged ?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
One hour for each ah the battery is
so if its a 8ah battery charge it for 8 hours
Posted on Jun 07, 2012
  • 156 Answers
SOURCE: Peg Perego 800 Twin ATV - Only runs for 10 - 15 minutes at a time
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
Posted on Jun 03, 2009
SOURCE: Does not run when I push the pedal, it is brand
OMG! The exact same situation here! Bought through Amazon, no warranty. I am so bummed. It was rode 5 times by a five year old on flat ground. Now it is a brand new, non operational, made in China piece of $500- junk! I am furious!!!When you press on pedal, nothing happens, fully charged battery, etc. Volt meter even confirmed fully charged battery. What ever happened in your situation? I am so hesitant to buy other parts, or send it here, to put more money into an overpriced piece of ****. Way to ruin Christmas!
Posted on Feb 04, 2010
SOURCE: how long to charge 12 volt battery
we bought a new one about a month ago, and the sales rep was very unhelpful in telling us how long to charge it for, so we just do it for 10 hours, our little man get's a couple of days ride out of it, between 4-5 hours ride time all up, hope this has helped?...
Posted on May 08, 2010
  • 156 Answers
SOURCE: the 12 volt battery will not take a charge, we
It sounds like the battery is not going to take a charge. My Grandkids have many of these toys and I get my parts from mypegperegoparts.com
here is were I buy my batteries because they have a coupon they let me use
http://www.mypegperegoparts.com/iakb0501.html
I also call them when I need help at 1.801.655.0800.
Hope this helps
Posted on Nov 05, 2010
  • 110 Answers
SOURCE: how long do i need
hi, 8-12 hours, if you're using the peg charger, it will shut off when charged so dont worry about over charging if its longer.
Posted on Jan 29, 2011
Yamaha 450 Kodiak battery not charging, new battery, volt meter not showing any voltage going to the battery
Hi Brian, get a digital volt meter and start the ATV measure the voltage at the battery or at the alternator it should read around 14 volts when charging, if it reads 12 volts the charging system is not working, check or a blown fuse or broken wire, if you can access the alternator directly measure at that point. It takes 14 volt output from the alternator to charge a 12 volt battery
May 06, 2017 | Yamaha 2005 Kodiak 450 Auto 4x4
How to check charging system on a kohler 17.5
This is an easy check if you have a cheap, simple volt meter. It's much better to have an old fashioned needle meter rather than a digital. The needle is more sensitive, much quicker, and makes a clearer diagnostic tool. But not to worry, for you fancy folks a digital still works (sometimes the results are not as clear).
  1. Set the meter to DC Volts.
  2. Attach the red and black leads of the meter to the positive and negative posts of the battery. Most modern day digital meters don't care if the polarity is correct or not. However, if you have a needle meter, best to put the positive of the battery with the red wire of the meter; otherwise the needle will not be happy with you.
  3. Note voltage. It should read near13 volts if the battery is good and fully charged. If it reads below 12 volts it needs charged or it has bad cells. If after charging a few hours, the voltage is still below 12 volts then the cells are bad, replace it.
  4. Turn the key to crank the engine while keeping your eyes on the meter. Whether the engine cranks or not, the meter should not fall much below 11 Volts. If it falls below 10 volts or worse yet below 9 volts, the battery has a bad cell or two. Replace the battery, charge it, and repeat the test.
  5. If the engine starts, rev it up and watch the meter.
    1. If the charging system is working the voltage on the meter should quickly rise above 13 or 14 volts.
    2. If it rises up strongly towards the 14 volt range this indicates the charging system of the machine is working.
    3. If it plays around down near 12 volts you are reading the recovered voltage of a good battery, but the charging system is not working.
    4. If it simply stays below 11 volts, the battery and the charging system are both suspect. Replace the battery first. Fully charge it, and then repeat the tests before worrying about the charging system.
Note:if the battery falls below 9 volts the fuel cut off, a black cylinder on the bottom of the carburetor (if your model has this), will cut off the gas supply to the carburetor.
Mar 15, 2015 | Garden
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
How long to charge 12 volt battery
May 07, 2010 | Peg Perego John Deere Gator HPX Ride on...
I have a 1998 Nissan Frontier and I believe there is an electrical problem but I don't know where to look. i noticed that my ''Brake'' and ''Battery'' light was coming on and off and when it did my...
With a volt meter and the engine at idle, check the voltage at the battery.It should always be just over 12 up to 14 volts. At idle with no accessorys on (lights, fan, radio ect.) The voltage should stay just over 12 volts. As you turn on all the accessorys the voltage should rise up to between 12-14 volts.
Also, a new battery needs to be fully charge before use. Most new batterys sit on the shelf and lose charge. My last new battery needed 8 hours of chargeing to be fully charged.
I hope this helps.
Sep 03, 2009 | 1998 Nissan Frontier
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Not charging {I think }
I assume that you have a meter of some sort as you stated the voltage as 16v.
test the battery voltage with the engine off, should be 12.4 volts or there abouts.
then test it again with the engine running, 14 to 16 volts should show a charge. Turn it all off and leave for 30 mins to an hour and retest the battery with the engine off, if the reading is lower than 12 volt then the battery is faulty.
May 02, 2009 | 1983 Honda XL 125 R
Peg Perego 12 Volt Rechargeable Battery Logo
121 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
