Question about Xantrex Technology Electronics - Others
I really screwed up this time! My daughter was listening to cartoons at the cottage this past week-end, and I didn't want to interrupt when I was moving a light fixture... I thought having the light switch off was good enough... When I pulled the wires out of the junction box, they produced a spark! My Xantrex X-power 1000W was dead! I have a red light "failure" on the device... Having paid it half price at $85, just wondering if I should ******* and take it like a man, or there's an easy fix? I peaked inside and it looks like there's 4 fuses at a very tight spot of course... I also saw by searching online that the new models from xantrex all have GFI outlet... Very smart!
    New Friend:
    Problem Solver:
  • 18 Answers
The red light fault you experienced was from the short, which caused an 'overload' on the device. It is designed to shut itself down under such conditions so as to not cause major harm to the unit.
It may correct the fault indication after the short is removed (ie: no more playing with electronics when you are not so trained), and the unit should work again.
Your mention of the fuses being in a "very tight spot" is typical in most such devices to make them as small and inconspicuous as possible. Working on such devices requires the technical expertise in dismantling and testing, then making needed repairs before again restoring the proper construction. Be very careful because you can damage other components by not handling carefully, and with the proper equipment.
Posted on Apr 20, 2017
  • 55 Answers
SOURCE: Connecting Cat5e cable to BT 78A junction box
You can get this device to help you.
http://www.run-it-direct.co.uk/run-IT-direct%20Price%20List.pdf
I believe it is on the 8th page.
Posted on Oct 17, 2008
  • 13433 Answers
SOURCE: Bosch Dishwasher SMU 2046
It doesn't work at all If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Oct 20, 2008
  • 360 Answers
SOURCE: GFI 'shorted'
load neutral connects to the neutral binding screw on the GFI, do NOT connect the load neutral to the neutral bar.
Posted on Mar 05, 2009
cj2176
  • 520 Answers
SOURCE: Wiring Door jamb switch
I'm going to guide you on how to create what is known as a "switch leg".
1- run a 12-2 w/ground wire to the light fixture from new switch.
2- connect black wire "hot wire" to the shiny bronze tinted terminal on switch.
3- connect the white wire " neutral " to the silver connection on switch.
4- connect the naked copper wire " ground " to the ground terminal on switch
5- Disconnect the two white wires in the junction box from each other.
6- Connect the ground to ground in j-box
7- Connect the black to one of the whites in j-box
8- connect the white to the other white in j-box
9- wire nut and tape all connections
Oh and be sure that you turn off the breaker before you start. Hope this helps. Good luck.
Posted on Jun 15, 2009
  • 4 Answers
SOURCE: my Xantrex rs400 stop working
First and foremost, It's a piece of ****!
I've been fighting with Xantrex for 3 years now and after 3 replacements I'm still stuck with the same erratic behavior. I don't trust it and Xantrex is not even responding anymore.
This is my review at Amazon
http://www.amazon.com/XS400-400w-Sine-Wave-Inverter/dp/B000A7MW5E/ref=sr_1_1?ie=UTF8&s=sporting-goods&qid=1256963563&sr=8-1
I know this is not helping you much but I thought it would be nice to know that you are not alone!
Richard
Posted on Feb 14, 2010
A father that never got to meet his daughter and to find out she had past away befor he ever knew about her A father that never got to meet his daug
Here you go Shirley, click the link. I was brought up in Shirley, West Midlands, UK.
Very sad story. I know this has happened many times. I knew a newspaper photographer who searched for his mother, and he died two weeks after he met her for the first time!
father that never got to meet his daughter and to find out she had past...
Dec 11, 2016 | Cars & Trucks
Web Design or 3D Cartoon?
I would move with cartoon since internet layout is really all programing mainly. Nonetheless, it is your responsibility everything you sense more powerful at.
I am examining media and internet layout is a type in which you software in dreamweaver (I loathe the software) and you also get rated on style although perhaps not programing.
Cartoon is interesting, there is less development and also you take pleasure in the result more!
Regarding the additional factors, money-wise it truly depends, cartoon can definitely move heavy and function situations are truly endless but you might have to be great to get them or you also wind up with small occupations all over that may additionally create an adequate amount in the event you are great and really know how to locate the most suitable individuals.
However net style is around and everybody can do using a web site but additionally tons of folks performing it previously so that you should stick out to be seen! Properly that goes for equally issues!n Though more individuals performing internet style I presume but standing out from the bunch is vital!
Health-wise it will depend just how quickly you perform and what occupation you selected, in case you get employed with a corporation it depends exactly what deadlines and what task you choose! For both occupations it is possible to be offered period of monthly or a couple of weeks or 2 4 hrs therefore less the particular occupation (they're equally related) but the special occupation inside the occupation which you're offered!)
Equally need a pc and I am positive you know the health hazards entailed there therefore I wont get into depth about this.
In which you get the occupation cash all depends. Possibly more would be made by cartoon.
To remain away without a doubt, here is a case of a Web Development I am aware:
Consider the listing of his abilities. He's been operating on web sites because he was 1 5 I believe, nicely that is when I satisfied him and he created a discussion group, after which yet another, and a website for downloads then this which and he did not actually get to university and he was employed at Mdr-V6 creating web sites for forthcoming pictures along with a number of additional items they request him to do! He claims it is a difficult work but I will observe him loving themself and nevertheless having some free time for his private jobs!
Trust that assists some! Basically were you I Would consider a media lessons, it handles internet style and Display and cartoon and after that when you notice that which you enjoy you're able to focus farther or maintain the measure and locate work!
Source: http://www.elixirmedia.co.uk
Apr 15, 2014 | Computers & Internet
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
When I turn it on the screen turns white. The
When I turn it on the screen turns white. The screen is all screwed up. I can still listen to music, I just can't see the menu or tell what anything says
Jul 08, 2010 | Philips GoGear ViBE Digital Media Player
Venting cottage plumbing system after installing a new holding tank. Connectng the two toilents to the holding tank
Hi Neil, W/D here.
There's really nothing special to do after connecting new materials to an existing drain system except to cycle them several times to establish (or reestablish) you water seals in your bowls and traps to prevent sewer gasses from entering your cottage. Code standards have vents built into your cottage, so additional venting should not be required, provided you are built to code, and you have good water seals in your plumbing fixtures.
Hope that this answered your issue. Best regards, --W/D--
Aug 13, 2009 | Washing Machines
Need screws for cottage crib by rockland
1-800-933-7115
This is the number for replacement parts for furniture at jcpenney. i ordered new harware for my caden convertible crib
Jan 20, 2009 | JCPenney All-in-One Nursery Crib
Dvd player
If you have a factory DVD player, then while the DVD player is on, press your radio preset numbers' 2 and 4 simultaneously. Then to listen to the CD or radio just press whichever button you want to listen to. You should hear sound out of your front speakers only, and won't interrupt the headphones. Good luck.
Nov 02, 2008 | 2005 Ford Freestyle
Signal Interruptions - Static
I hope that you have had this unit for a while because it has been out of date for quite some time. I had this unit as well and furtunately the problems exsisted while under warrenty and I was able to get it fixed. Version 2 seemed to be better, the (A2). Sorry for the info, but vA1 was a bad unit if you ask me.
Jun 15, 2007 | Kenwood KTC-H2A1 SIRIUS Radio Receiver
Electronics - Others Logo
332 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
EE Eddie
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
