Question about Acer Computers & Internet
Motherboard faulty, repair, scrap machine, or replace motherboard ? What is the cost and complexity to have fitted a new motherboard fitted to a acer as 5101wlm computer?.is ths repair durable and worthwhile Have I any come back as the machine is around 18 months old the retailers Watford Electronics went into recievership, the item was bought by credit card. Thank you
    Novelist:
    Scholar:
  • 96 Answers
Firstly, check to see if your manufacturer's warranty is still active. As long as it is not a custom-made machine, you should still have warranty repair service if you bought a service contract. Most of the time, a service contract comes with the purchase. at 18 months, most contracts will still ship you replacement parts but you will have to put it together.
If the retailer sold you their own custom made computer, then you have very little choice. The repair costs are going to vary according to where you live, but here's a general rule of thumb to go by: If the repairs cost more than 3/4 of that what a comparable replacement PC would cost, then go get a new one. Some stores will give you credit for exchanging old PC's. look around for stores doing that, as this will be the only way to recoup some of your costs.
Altrnatively, you can donate the computer as scrap to local charity who will take it apart and sell the parts. you will get full retail value as a write-of on your tax returns at the end of the year. Of course, this is only helpful if you file itemized deductions.
Posted on Jul 09, 2008
I am told my Elna 7000 motherboard is beyond repair and I will have to replace machine as it is not worth replacing motherboard. Can this be true ?
you might check with another sewing machine shop and see what they tell you, you would have to consider the cost of replacing the motherboard and the price of a new machine
May 27, 2016 | Elna Sewing Machines
Can I change the ethernet port on my Dell xps 200 or is it connected to motherboard?
If it is broken, you can add a new ethernet port by adding an expansion card. Also, this would be the way to upgrade it.
The ethernet port is soldered to the motherboard, so if the port itself was damaged, you could have someone desolder it and solder on a new one, but the cost of labor would likely exceed the price of buying a replacement motherboard. Still, you would have the cost of labor to replace the motherboard, so the most cost effective solution is to add an ethernet card, which you can easily do yourself. You could replace the motherboard yourself, but that is much more complex.
May 08, 2015 | Computers & Internet
My laptop acer aspireone mini laptop screen is blackout i can't get it started.
You might have a faulty Liquid Crystal Display [LCD] Panel Power Inverter. Or the LCD Panel itself might be faulty. Either can be replaced. The Inverter is relatively inexpensive, a replacement LCD Panel, a little more.
To test for a faulty screen, connect your notebook to an external Desktop Monitor, using a standard VGA Cable -> press and hold the Fn key bottom left of your keyboard -> press the Function key at the top of your keyboard with the image of the two monitors on it -> release both keys -> if the image sent to the external monitor is correct then the fault is likely to be in one of the components of the LCD Screen and you should take the notebook to a repair centre to test test and replace the faulty component(s).
If you cannot start the computer at all, but there is a constant or flashing Power Light Emitting Diode [LED] on at the front but no Hard Disk Drive [HDD] LED on, then either the battery is faulty, there is a loose Direct ()Electrical) Current [DC] Jack, the Graphical Processing Unit [GPU] chip is faulty or there is a damaged Motherboard Power Management Track.
To eliminate other possible causes of the symptoms you describe, remove the battery and connect the notebook directly to the mains electricity without a battery and then try to power the notebook up. If the notebook powers up and boots into its Operating System then the battery cells are probably depleted and cannot recharge, so the battery should be tested and, if found faulty, replaced.
If the battery is not the problem, check for a loose DC Jack. If the point where the the Power Cable connects to the notebook is loose and is either in intermittent contact or not at all in contact with its solder points on the motherboard, then power might not be reaching the motherboard. Loose DC Jacks can be re-soldered or replaced if damaged.
A loose DC Jack that is in intermittent contact with the motherboard, an electrical power surge or sudden power cut or disconnection of the power cable can damage the Power Management System of the motherboard. It is sometimes possible to repair Power Management problem afflicted notebook motherboards by replacing blown capacitors and/or bypassing burnt out or damaged circuit tracks by creating new ones. Extensive damage to a motherboard might make it uneconomical to repair. Replacement motherboards are available and could be installed but when combined with the cost of labor for the overall repair the price might be prohibitively high.
A faulty GPU can have new tracks made to it, or have a damaged chip (silicon chip) surface cleaned to restore lost graphics by two different processes, Ball Graphics Array (BGA) Reflowing or BGA Re-balling. Re-balling has the longer lasting and better success rate. When the surface of the GPU is too damaged it may not be possible to repair it.
All of these motherboard repairs require a laptop repair specialist to disassemble the notebook and test, replace or repair any faulty components. These repairs can be expensive and need to be weighed up against the current value of the notebook and the cost of a new replacement notebook.
Nov 20, 2011 | Acer Aspire One PC Notebook
Green tinge on imedia s1800
This is generally caused when your display cable isn't plugged in all the way or has a broken pin. Make sure the cable is seated at both ends, if it still is bad remove the cable and check for bent or missing pins, if yes replace the cable.
Nov 08, 2011 | Acer Computers & Internet
Compatible motherboard for Compaq Presario CQ61
Hi
You do not say what the problem is with the original motherboard. It certainly used to be the case, not so long ago, that a fault on a laptop motherboard almost invariably meant a either new motherboard or a dead laptop. The onward march of innovative, efficient, effective and economically viable Repair Technologies and Stratagies have rendered the old proposition untrue in today's repair market. Several key internal components of Laptop motherboards that were previously highly problematic when faulty, can now easily be repaired. Blown capacitors can be replaced, damaged tracks can be bypassed and re-laid, loose or damaged DC Jacks, broken USB ports, faulty sockets, briken off or missing pins and connectors can all be resoldered or replaced and motherboard chips can be cleaned, resurfaced and rehabilitated.
If you add a comment/clarification to this question about the state of the original motherboard you will receive additional advice that might possibly save you the cost of a new motherboard, which can be prohibitively expensive.
There is no such thing as a "compatible" laptop motherboard. Only a genuine, original motherboard, exactly the correct size and shape, with all the correct cable connections, exactly the correct spaces for internal devices and exactly the correct port geography to match the size poisition, orientation and shape of the portholes in the chassis and frame will fit AND work.
There is only one source for that - the manufacturer of the original motherboard.
You can source and order this part from your nearest authorized HP (current owner of Compaq) stockist, who has the genuine replacement part product in stock, by looking on the underneath of the existing motherboard and entering the full, correct part number of the motherboard here (guidelines are available on the website):
http://h20141.www2.hp.com/Hpparts/part_search.aspx?mscssid=9DCC8FB468A946F1A6415C99B410062F&NoMatch=true
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Sep 05, 2011 | Computers & Internet
IN MY MOTHERBOARD RAM SLOT IS CORRUPTED WHAT IS THE SOLUTION?
If the ram/memory module is faulty then it can be easily replaced. If the ram slot is faulty the you may need to replace the whole system board.
Feb 28, 2011 | Intel Motherboard
Hi,my computer has stopped working and just beeps at me. mother boardis a Microstar P4m266-8235. Please Help......Thank You
This problem could be due to carious problems.
1) Your motherboard is faulty.
2) Your Processor is faulty.
3) Your RAM chip/s are faulty.
Firstly, you will need to unplug your computer and open it up. Then you need to locate the RAM which looks like this:
Remove one piece of RAM (assuming you have more than one piece) and try to start the computer again, then if it doesn't work, remove the other chip and reinsert the chip that was first removed and try to power up again.
If it works, then one of the RAM chips were faulty and you will need to replace them.
If the computer still does not work, then either your Motherboard or Processor are faulty.
You should then buy a new motherboard which isn't too expensive (be sure to buy a motherboard that will fit in your computer and will also be able to handle your processor.). Place the motherboard with the RAM in to the computer case after removing the old motherboard. Then carefully remove the processor from the old one and put it in to the new one.
Be sure to re-insert any cables that you have unplugged from the old motherboard in to the new one. Then try and power up once the machine has safely been closed again.
If the computer works, the motherboard was faulty. If it still does not work, then your processor is faulty and you will need to buy a new processor and install it.
Alternatively, you can take the computer to a repairman who will test the various components which will save you the hassle of doing all of that work and it will also save you the cost of having to buy new RAM and a new motherboard if in fact it is actually your processor that is faulty.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Jan 10, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Motherboard on my sony VGN-AR71M NEEDS REPLACEMENT
It maybe repairable... needs a New BIOS Chip. This is a Local Job for a Tech... my guess $250.
Motherboard Costs more Labor about the same... $350 is a guess.
Search a Local Repair shop certified in SONY Laptops... :)
Dec 31, 2009 | Sony (A-8059-921-A) Motherboard
LG RD405 MOTHERBOARD PROB.
Before you decide replacing the motherboard, have you determined the fault in the laptop?
I suggest you attach a monitor to the laptop and power up the monitor then bootup the laptop. This will automatically switch the video data to the external monitor. If you don't get a normal Windows image then you could have a faulty video card or faulty memory.
In a laptop the video card uses part of the main RAM (memory), try re-seating the RAM module/s and see if this corrects the problem.
If not you could have faulty RAM module/s, take them to your friendly computer repair shop and get them to test them for you. If these are OK then you definitely have a faulty video chip problem. This is part of the motherboard and the fix is a replacement motherboard.
Replacing the motherboard may not be a cost effective solution, but it depends upon the age of the laptop and the costs of repair.
If you decide to get a new laptop, you can salvage the hard drive from this laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
Nov 29, 2009 | LG X-Note LM50 Notebook
Iriver H340 motherboard?
Hi , the price of the motherboard you might as well buy a newe Iriver mate , but if you wanted you might be able to salvage one from a broken I river on an auction site since replacements are not readily avalible for the public .. and as for complexity ,
it shouldnt be too hard but technician to preform the repair job would save alot of hastle in the long run.
Apr 02, 2008 | iRiver H340 MP3 Player
Computers & Internet Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
