Question about Gaggia Evolution Espresso Machine
Pump problem on a Gaggia Espresso Evolution
Hi, my Gaggia is not drawing water into the pump. I've tried the suggested solution of forcing water into the pump by syringing it up the intake hose, but with no luck. Thinking that it could be an airlock that ain't shifting, I took a hammer to the pump - gently of course. Also to no avail. Everything else on the machine seems to work correctly - heater, steamer. My coffee cups and jar of Illy look sad and forlorn - help needed quickly please!
  • 1 more comment
  • fixfaxfox Jul 20, 2008
    Hi thanks for this. Tried this but with no success. Guess the pump is probably dead.....
  • Anonymous Mar 11, 2009
    Giles Broe: 07801 869 109
  • Anonymous Mar 31, 2014
    manual
  • 515 Answers
You need a bellows pump or similar, when you start the pump you need to set the pump to the water inlet and press in the water with force.
Posted on Jul 13, 2008
  • Mirko Blas
    Mirko Blas Jul 20, 2008
    Ok,
    I have spare part number to the pump. It is 187721758.
    Hope you get your machine to work again.
The pump does not run water through the filter head. It makes a noise and pumps the hot water back into the water tank
Almost certainly due to the reverse side of the brewhead being scaled up. The evolution has a recess on the reverse of the head that block causing no water to come out. Remove the head and clean it off.
Dec 31, 2009 | Gaggia Evolution Espresso Machine
My gaggia evolution leaks water while making coffee .It appears to be coming from inside the machine and leaks everywhere.I have disassembled the machine but i still can 't see where the water is coming...
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
Oct 22, 2009 | Gaggia Evolution Espresso Machine
When the hot water switch is pressed, no water is pumped.
group head is blocked. remove centre screw from the group head remove spring and valve, clean and re assemble.
Sep 20, 2009 | Gaggia Evolution Espresso Machine
Gaggia Evolution Espresso won't heat up
1 heating element defect(needs replacement)
2 security termistat, (replacement or reset)
Mar 25, 2009 | Gaggia Evolution Espresso Machine
Gaggia evolution not producing coffee
One question before I make any suggestions: If you remove the shower screen and screw, do you get a nice flow of water or is it still steam?
If you get a nice flow of water, then check your screen hold it up to the light and you should be able to see through the tiny holes, if not, get a pair of needle nose pliers and being very careful hold screen over an open flame like the stove burner. The coffee will burn before the anything happens to the metal. When it is cooled screw into group and see if the flow of water is better.
If you get nothing but steam then it is time to descale the machine.
Feb 27, 2009 | Gaggia Evolution Espresso Machine
Gaggia Syncrony
I think you get air in the system, try to find a bellow pump or similary and force in water in the water tank inlet. Make sure you open the steam knob when you do this.
Hope this will help you.
/Mirran
Aug 09, 2008 | Gaggia Syncrony Compact Coffee...
Low water flow from gaggia evolution only 6 months old, have tried descaling, no obvious scale found in machine. pump starts but goes quiet, very feeble flow of water.
I have now solved this problem. The lack of flow associated with the pump working but running quietly is caused by the Group Head being blocked with limescale. Normal descaling cannot remove it because it cannot penetrate the Group Head.
Removing the Group Bell can be achieved using a collection of screws (see photo) and works no matter how stubborn the thing: levering it with a screwdriver in my case was impossible as it was so well glued on. 6d47425.jpg
I figure that the advice to replace the rubber seal once per year is a good one because it forces you to remove the Group Bell and clean it out.
Apr 29, 2008 | Gaggia Baby Espresso Machine
Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
May 21, 2007 | Gaggia Evolution Espresso Machine
Gaggia Evolution Espresso Machine Logo
1,003 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
