Question about HP Pavilion dv9000z Notebook
Where do you plug in earphones on this laptop ?
    Genius:
  • 1,288 Answers
On the side of the laptop, headphone and mic jacks next to each other
Posted on Jan 03, 2011
Sound does not transfer from laptop to earphones when they are plugged in. Tested earphone and test was good. How do I get the sound to come out of the earphones instead of laptop?
I would guess there is a fault with with the earphone jack socket, the soldering to the printed circuit board or perhaps some of the electronic components that might or might not provide attenuation and/or tone correction for the earphones.
Probably be a cheaper cure to use bluetooth.
I use a usb FM transmitter so my sound files can be played on any nearby FM radio.
Dec 03, 2015 | Compaq Computers & Internet
When I plug my earphones into the headphone jack, the sound still comes through the laptop speakers, not the earphones
Forgive if this is too simplistic, but 2 suggestions before digging into the laptop: Confirm that you are plugging into the headphone jack and not the mic jack. Second, try a different set of earphones - sometimes buds with a mic capability like for a cell phone don't respond the same as pure headset.
Nov 15, 2014 | Samsung 550P5c 15.6 Inch Laptop - Black...
Earphone jack on my compaq presario c700 stopped working. How do I fix it?
You will need professional help on this, the laptop must be dismantled down to the motherboard level to access the problem. The earphone jack may have to be replaced and requires a high degree of solder skills to remedy the situation.
Apr 03, 2012 | Compaq Presario Computers & Internet
Can Acer laptop drive the Logitech S220 2.1 Speaker System with Subwoofer?
sure can, any standard sound amplifier can take a signal from the stereo earphone jack and amplify with fantastic results.
Just need to go to Radio Shack or Walmart, or another department store to get the right adapter (stereo to stereo, or stereo to mono) and cord.
Note the number of contacts on the earphone plug that plugs into the earphone jack. If it has three different connections on the plug, it's stereo. If it has only 2 then it is mono.
Most computers I know of have the stereo plug which works with stereo inputs of an amplifier.
So, the answer is a resounding yes.
Jul 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
No sound from laptop
The simple damage your laptop and here is you can not move but the socket earphone / headset of your laptop,the opening of outlets are you have seen lock switch is you just poke a gently using the little things like the end of ball pen.good luck and hopefully helped revenue
Dec 12, 2009 | Compaq Presario Notebook
In my c700 the prblem is with audio system. when earphones are fixed to laptop the sound comes from earphone and normal speakers both.tell me what to do?
go to the windows start button - control panel - sound.
Then take a look a the settings, with the earphones plugged in and out.
Maybe, you have to deactivate the normal sound system, while the earphones are plugged in.
Or maybe you see some settings there to control the outgoing sound.
Jun 12, 2009 | Compaq Presario 700 470024-192 Notebook
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
No sound from ear phones of Fujitsu S-series laptop
First ensure that the headphones are working, by testing them on a divverent devices.
Ensure that computer has sound from speakers, if computer has not sound at all , then you need to reinstall audio drivers.
Then restart the computer with earphone plugged in, this solves a bios control related problem.
If still no luck, than you may have a broken solder joint on the Jack socket, in that case the repair must be done by a technician.
Jan 07, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Laptop speakers working, ear phones not working
Check when you plug in the headphone the laptop speakers get off or not also see the audio configuration under control panel sound that you choose digital sound or its having channels system like 5.1 or 7.1 channels you have to configure it to headphone
Jun 29, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv9000z Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
