Question about Reddy Heater-30-55,000 BTU Variable
MY READY HEATER STARS FOR 3 SECONDS THEN SHOUT DOWN
    Scholar:
  • 146 Answers
This can be from either a bad connection from the thermocouple to the gas valve or it could be a bad high limit switch.
If you run a jumper wire between the two leads on the thermocouple and the units runs then you may need to replace the High limit Switch.
If that does not solve the problem then clean the end of the thermocouple lead that goes into the gas valve.
Thanks
M Cramer
www.allpartsinc.com
Posted on Jan 04, 2011
How do I stop the stars from blinking on a fossil watch
Hold button down for 2 seconds to alternate between different modes i.e. Flashing, not flashing, light always on.
Oct 01, 2014 | Fossil Watches
Tip
Robotek - your "Type 2" method worked like a charm on my Kenwood KDC-MP5028...
Hi there, there is a standard procedure we use to bypass the code when we have the gear on the test bench for repair. Try this and it should sort out your problem
You need the remote control to do this, if you don't have one, then you may need to go to a KENWOOD agent and get them to clear the code for you, or purchase one for your use.
KENWOOD KDC SECURITY CODE CLEAR procedure
Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
The security is canceled and the set enters the TUNER mode!
:) POSITIVE FEEDBACK :)
A FixYa rating would be fantastic for helping you out with this techo tip.:)
A FixYa vote is a great reward for the challenge of solving your problem
ask Robotek
on Jan 26, 2011 | Kenwood KDC-135 CD Player
Hayward Heater H series 400 BTU will not start
This is a normal display when heater is being controlled by a remote thermostat. No service is required. If heater is not being controlled by remote thermostat, change setting by using the MODE key to put the heater into STANDBY. Press and hold the DOWN key and then press and hold the MODE key. HOLD down both keys for 3 seconds until the indication "bo" is removed from the display.
The key to this is DOWN first and then together with MODE, both for 3 seconds.
Make sure the display is not showing "BD".
Jul 06, 2017 | Hayward H Series Pool & Spa Heater 400k...
Ready heater r110 I have replaced nozzle, filers all, cleaned sensor, runs some times for 30 sec shuts down
The R110 is a spark plug heater, as you know. It does not have the sophisticated electronics that the newer heaters have.
My guess: SP heater runs 30 seconds & shuts down- bypassphotocell. If it runs fine, then the photocell is defective.The test is simpleIf the photocell proves to be good follow these troubleshooting tips
Oct 13, 2011 | Reddy Heater-30-55,000 BTU Variable
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Jan 26, 2010 | Rancilio Silvia Espresso Machine
BMW series 3 fan for cabin problem
Remove the Heater / AC control unit and then check if it still runs when the car is off. If not then the control unit is faulty.
Aug 03, 2009 | 2000 BMW 3 Series
No Picture
1. If you are using TIFF mode for uncompressed images, the camera takes much longer to process the image because of the very large file size. It takes longer between shots and longer to play back a TIFF image. The TIFF setting on the camera Top LCD Display is 'No Stars' (One Star = Basic, Two Stars = Normal, Three Stars = High Resolution, No Stars = be patient for TIFF). Unless you are doing professional images, we suggest that you use the normal or high resolution JPG settings (Two or Three Stars / FULL) for good results. 2. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 3. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. 4. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
No Picture
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Reddy Heater-30-55,000 BTU Variable Logo
62 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
