Question about Canon PowerShot A720 IS Digital Camera
The latch for the battery cover on my Power Shot A720 IS is broken. Can it be fixed?
    New Friend:
  • 58 Answers
Probably not as the cause is most likely broken molded plastic parts that where to small and thin to last very long. Seems to be a common problem on this otherwise great pocket camera. Use tap or a rubber band to keep the battery cover closed so the contacts still work. Bad design by Canon.
Posted on Sep 08, 2014
SOURCE: Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Posted on May 10, 2008
t00nz
  • 4738 Answers
SOURCE: My canon power shot A720 IS won't turn on...
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 18, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony DSC-T70 CyberShot memory/battery cover broken
Assuming that your Sony DSC-t70 has black color cabinet then you need battery Compartment with following part number...
X-2186-609-1 ASSY, BTH (B) (BLACK)
IMPORTANT (If camera has different color cabinet, let me know to provide you appropriate part number)
Above said part is available in Part Store on $33.42
Posted on Dec 06, 2008
  • 5 Answers
SOURCE: Broken battery latch cover
no, is not practical to repair. you can do bigger mass what is now. only what you can do is secure cover with self-adhesive tape. if you not satisfied with this, go to service and pay repair.
Posted on Mar 25, 2009
Obertelli
  • 3006 Answers
SOURCE: Cover latch for battery door broken on my Coolpix
This is a really common problem affecting this camera and the near identical Coolpix 2100 (and a few others).
If I'm correct, then the door latch has nothing to lock into on the camera body because the corresponding catch has broken off. Depending on how the break has occurred the body either has one or two small plastic pegs just where you'd expect the battery cover to latch onto or even no pegs and just barely visible evidence of where the catch used to be. The two pegs (or the site where they were) used to form a small soccer goal shape. The top of the goal (crossbar) broke away and sometimes takes away one or both goalposts with it. I've successfully repaired six of these now for various family members and friends.
Both are an easy fix, and if you live in Europe and pay postage I'll do it for free (I'm in London). if you live further afield, my offer still holds good, but the postage may cost more than the camera is worth.
To do it yourself you'll need patience, a sharp craft knife/scalpel, a jewellers file, a miniature pair of long-nosed pliers with a wire cutter, thirty minute epoxy resin and a standard small paperclip. Regarding the jewellers file: this needs to be a flat profile and about 5mm wide (not critical) and about 1mm thick, i.e. about the same thickness as the paperclip wire, and must have cutting teeth on the thin edges as well: this is vital.
First, straighten the paperclip. It needs to be as straight as you can get it as it make the rest of ther repair easier. This will form the new battery catch, so you need to use the pliers to shape it. The new "goalposts" will have deep roots held by the epoxy redin, so start bending at the centre of the wire. You need to end up with a cross bar which is the same width as the original plastic one, which has sharp right angle bends down to each goalpost which will be longer than needed at first. The long nose pliers taper so you can grip the wire in the pliers at just the point where bending the goalposts down will result in a goal of exactly the right width. It is easy, but takes a few goes to get exactly right and you may need a few paperclips until it's perfect. Precision is vital to a good repair which looks original.
Next, you need to use the file and the craft knife. If the goalposts remain, then use the knife to cut them off flush to the surrounding edge. Using either the knife or the file, cut out two slots where the goalposts were so that they're as precise a fit as possible for the paperclip wire. If you look into the battery chamber there will be a few plastic strenghthening webs, so use both tools to cut these to allow the two goalposts to sit well down into the battery chamber. Go slowly and carefully as the more accurate you are, the better the job.
Next, test fit the new catch into the slots you have just cut. It needs to be a perfect fit and needs to lay comfortably and flat into the slots. You should be able to slide the goalposts right down until the crossbar almost touches the edge of the battery chamber. The crossbar needs to be parallel to the edge of the battery chamber. At this stage you may find that you have to modify the wire a bit or even discard it and start again.
Now mix up the epoxy resin, and using a suitable tool put plenty of it down into the battery chamber between the strengthening webs which you've just cut, basically fill the areas bounded by the remaining webs, and go much lighter with the glue as you get near the edge of the chamber where the battery door will close. You don't want to get glue right up to the edge. Be careful not to make a mess and don't get the glue everywhere.
Coat the goalposts with the glue up to within about 5mm of the crossbar and lay the wire into the slots, using your tools to push the roots of the goalposts well into their slots. This is where all the careful cutting and wire bending will show
Once complete, you should find that the new catch (goal) you have just made will slide comfortably down into the slots you've just made. At first, set the height of the crossbar by eye so that the underside is about 1mm above the edge of the battery chamber and wipe off even the tiniest traces of stray glue which get onto the exposed parts of the catch or onto the edge of the battery chamber. Test fit the door latch into the catch: the mixed glue is quite thick even before it sets and should just hold the wire sufficiently for you to determine if the latch fits it correctly. The thirty minute setting time will give you time to make fine adjustments to the exact catch position. When you're happy, leave the camera with the battery door open somewhere for about 24 hours to enable the glue to fully cure. Although you've used thirty minute setting epoxy, it's still a bit flexible and nowhere near fully cured at this stage.
Afterwards, the battery door latch should engage into the catch as if it had been made that way by the factory. Now try it with the batteries fitted. It should be perfect, but if not there's usually enough give in the wire for final tiny tweaks to the fit.
I hope this has helped you, just sorry that I've never taken any pictures of the process. Your camera is basic but is still beautifully easy to use and even the 2.1MP version produces stunningly good photos, so this repair is worth doing.
Please return the favour by rating my answer.
Posted on Jul 13, 2009
I changed the batteries in my Power Shot A720 IS recently when the low battery warning flashed, and had taken only two photos when the warning flashed again. I moved the mode switch to playback and the...
Hi, 1st you must use alkline bat or minimum 800 mhp bat....
and if problem is not solved then cheak the bat cap and connection clean with aomthing,,,,
If any thing else contact me
Khatricamera@gmail.com
Mar 27, 2011 | Canon PowerShot A720 IS Digital Camera
The door that keeps the batteries and memory card will not stay closed. Can it be fixed?
Mine is broken also. There are 2 tabs in the cover and 2 raised slots on the camera body. When you open the battery compartment, you are supposed to slide the lid forward releasing the tabs from the slots, before the cover pops open. If you don't do this, you ~will~ break the tabs (or the raised slots). Well someone who didn't know this got a hold of my camera tried to force the compartment door open, breaking the raised slots that are part of the camera body.
Take a close look at yours and figure out how this latch is supposed to work and then see which part is broken. If it's the tabs on the door you can buy a replacement door online (do a search) and have someone good with electronics install it. (requires soldering). If (like me) it's the slots on the camera body that are broken, then it's not repairable. The original parts are too small and flimsy to be repaired (designed to fail). My best idea is to find some other way to latch the door closed. I've tried a velcro strap but it doesn't hold the lid tight enough and I've looked in hardware and craft stores for some kind of latch that might work, if I could atach it to the outside of the door somehow, but haven't found anything suitable (it would have to be small but sturdy and attach to the thin plastic of the door)
I'm thinking of taking it to a jeweler because they work with very small parts and might have something that could be screwed into the plastic door and camera body.
If you know of a better fix, please let me know.
Jun 15, 2010 | Canon PowerShot A720 IS Digital Camera
Time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
Jan 10, 2010 | Canon PowerShot A720 IS Digital Camera
Battery cover will not close when batteries are
The cover will close.
First, remove the batteries and try to close the latch.
Please "add comment" to let us know that it can close without batteries.
If it cannot close and latch, then the cover is broken.... can't fix here.
If you can close and latch it w/o batteries, then:
If you are using rechargeable batteries, they might be slightly bigger than alkaline batteries.
Put one alkaline battery in the camera and try to close and latch it. You may now know the "tricky" maneuver you have to do in order to close it with the batteries installed. Now try two batteries, etc. until you can maneuver all batteries.
I think this will work for you.
Sep 10, 2009 | Argus Cameras
Wont take pictures with flash
The problem is in the battery holder of the CR1220 battery.
-Take out the CR1220 battery (the little round one).
-When you replace it, put a bit of aluminum foil against the back, between the battery and the plastic holder, to make it a nice tight fit. One layer won't do it, but don't put in half the roll.
-Put it back in. Done
Using a fresh battery & clean it all with alcohol = good idea as well. Worked for me.
Wich
Apr 24, 2009 | Canon PowerShot A720 IS Digital Camera
The opening for the batteries is broken.
The 4 latches that the battery door locks onto is broke, you will need a different back cover and front cover.
Feb 26, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Canon power shot a270 is lens error
try to remove battery with lens out then put battery back in. If problem is still there you can gently try to push in the lens as its going in but service is recommended.
Jan 16, 2009 | Canon PowerShot A720 IS Digital Camera
May 17, 2008 | Canon PowerShot A700 Digital Camera
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Canon PowerShot A720 IS Digital Camera Logo
253 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
