Question about Brother Disney PE-400D Computerized Sewing Machine
BROTHER PE-8500 EMBROIDERY MACHINE TOUCH SCREEN PAD DOESN'T LINE UP WITH ICONS. HAD PROBLEM A YEAR AGO, TECHNICIAN DID ON-SCREEN MANIPULATION (EVIDENTLY A HIDDEN MENU) AND FIXED THE PROBLEM. CAN YOU HELP ME ACCESS THIS MENU AND SAVE A COUPLE HUNDRED DOLLARS/
  • Cheri Durbin
    Cheri Durbin Apr 20, 2009
    I have the same problem. I just tried this solution. The number menu comes up, but nothing happens when I try to select the numbers. Tried it with my finger and also a pointed manicure stick, mine didn't come with a stylus pen. And nothing...
    Is it supposed to beep or move or anything? Scratching my head and hoping to avoid a costly  repair bill..... Cheri
Never mind..I figured it out. Once you get to the number screen, you have to hold down the Start/Stop button while selecting the numbers. I did it 3 times and it worked! Icons are perfect now...Thanks!!!
Posted on Apr 20, 2009
I was told to do this and it worked for awhile. Finally, I had to have the screen replaced.
Machine is OFF. Push start/reverse/needle buttons all at the same time while turning the machine on. You may need help from someone else. When the screen comes up, select 1 2 3 4 5 in sequence with pen supplied with machine. Do this 3 times. Hope this helps!! Linda
Posted on Aug 05, 2008
How do i do a screen calibration on a PC-8500 sewing/embroidery machine?
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Pc-8500 how to calibrate touch screen
ADJUSTMENT
match.
Brother PE-770 motor reving but not sewing
Check that the embroidery arm is slid properly into the machine base. Otherwise, it is probably a problem that needs to be fixed by a service technician.
Mar 11, 2013 | Brother PE770 Computerized Sewing Machine
I have a Brother PC-8200 embroidery sewing machine. Last week I had done some embroidering then changed to straight sewing but couldn't get the tension to adjust. Took it in for repairs, and the...
That's a tough call, parts can be pretty high to fix a machine. Have looked around to price out a new embroidery machine, Janome makes some very nice one in that price range. I'd try ebay there is one which is missing the foot control and hoops for $250.00 just search Brother Pacesetter PC-8200 this may be the ticket you already have the foot control and hoops.
Best of luck
Jan 29, 2011 | Brother Disney PE-400D Computerized Sewing...
SETTING THE TIMING ON DISNEY BROTHER PE-180D EMBROIDERY MACHINE
Email me for attachment of instructions drivewithken@blueyonder.co.uk
Mar 05, 2010 | Brother Disney PE-180D Computerized Sewing...
Brother 8200/8500 Upgrade -- opening machine and replacing motherboard
hi, to open the pc-8200 first you need remove the right cover these have 1 screw under a plastic cap.
now you remove the 2 plastic cover in the left side upper and low these are onlu a screw in the back an remove pull to the left side.
Next remove the plastic cover where rest the embroidery these have two screw, you can see easy...
at this time you have only the front & rear cover, this have a hiden screw and lot of presure grapes.
if you need more help sendme a email adrianferra@hotmail.com
Jan 20, 2008 | Brother Disney PE-400D Computerized Sewing...
Brother Disney PE-400D Computerized Sewing Machine Logo
607 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
