Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Color is cloudy. the picture is far from being sharp.
  • Philips Master
  • 3,459 Answers
The fluid in the lenses has clouded over. This is common. You can get a CRT fluid repair kit from www.TvRepairKits.com .
Posted on Jan 28, 2011
How do I adjust the color contrast and sharpness ?
you can do that through display settings ..
right click on empty space on your desktop .. goto preferences. or goto control panel - display settings .. and you should be able to modify the same to desirable settings.
if that does not help .. then call 1-877-805-1027 for expert help
Aug 03, 2015 | Dell Inspiron Computers & Internet
I have a 1998 Mitsubishi VS 60603/ 873G projection television receiver. the picture is not sharp anymore, appears cloudy, what is the problem?
Mitsubishi Electric Customer Phone Number Shortest Wait Best Support
How to Fix Cloudy Spots in LCD TV Screens eHow
Dec 16, 2014 | Mitsubishi Televison & Video
Sreen has perfect color and then fades to a cloudy/faded picture. occassionally picture will go full color then very yellow,very red, cloudy/faded.
Does it come and go? Or is it like this all the time? If you bump the side of the TV does it change the symptoms? Thanks Lou
Aug 27, 2011 | Mitsubishi WS-55613 55" Rear Projection...
I have a WD 65831 Mitsubishi television. I love it and have had NO problems so far with it. The picture and letters on the screen seem slightly fuzzy (out of focus). I had the bulb burn out and I replaced...
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | Mitsubishi Diamond WD-65831 65" Projection...
Lack of definition, blurriness.
Experiment with lowering the "exposure compensation" setting until you get the desired results. Also, don't forget to use a tripod.
Jul 15, 2010 | Nikon Coolpix L110 Digital Camera
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
We are using the 55 rear tv to display our logo for a talk show.
I assume you purchased the tv in the current condition you are describing. Philips are notorious for having cloudy glyconol coolant. The coolant is situated in a chamber between the light tubes and the lenses and is required in order to keep the tubes running cool or they would otherwise crack from the excessive heat from the light tubes. The coolant normally becomes corrupted in the blue tube first, with the red and green tubes following closely behind it. The Video that is able to project through the cloudy coolant causes a picture that is washed out, fuzzy, and can even cause rainbowy colors depending on how many chambers are cloudy.
If you want further proof that the glyconol is corrupted, you can have someone remove the rear cover and take off the lenses from the light tubes so you can see directly into the coolant chambers to determine which ones are cloudy. Replacing the coolant is an involved process. You should attempt to return the tv to the sales person for a full refund if possible and explain the tv is not okay as he said.
Mar 12, 2009 | Philips 55PW9363 55" Rear Projection...
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Len
Nov 30, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cloudy screen/
More than Likely your Tubes are getting weak!, (3 tubes - Red, Blue, Green) Need Replacing or Rebuilding (fluid change). g.
Jun 26, 2008 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
