Question about Frigidaire ATF6000ES Front Load Washer
Have a water leak that is not from the hook up hoses. Not exactly sure where it is coming from.
  • Frigidaire Master
  • 2,536 Answers
Most likely it's coming from the rubber boot that connects to the front panel and to the tub.run your fingers all around the boot and you'll find the leak
Posted on Jan 03, 2011
Washing machine leaking at the back
I would start by checking your hose connections for the water lines, they look like a garden hose connection, and you can replace the rubber washers in the ends of the hoses. Make sure they are tight and look for where the water is coming from, sometimes you get lucky and its a water hose that loosened up from vibration over time. If its not coming from the water lines its most likely an internal seal on the drum, or a leaking connection at the water pump. I would try and track down exactly where its leaking from first and if its an easy fix like the water lines try that before calling for a service/repair service to come look at it, could save a lot of money!
Jan 11, 2018 | Washing Machines
Leaks water - not sure where it comes from. Thank
Coffee leaking into the drip tray could be from the brew unit or the front door assembly. Water leaking probably means a hose connection to the boiler has failed. Don't just leave it, fix leaks immediately. Besides the electrical danger, the rust on working parts from long term leaks can be extensive.
Are you confident? Operate the machine with all covers off to see where the leak comes from. Be extremely careful, ready to pull the plug at any moment. Touch nothing inside! Burning, scalding and electrified! Check both boilers very closely while making coffee, most leaks become obvious on close examination.
Most leaks are due to failed o-rings in the connectors at the end of the teflon hoses, usually at the coffee boiler. Replacing the o-rings should stop the leak.
Source replacement o-rings. Slide the hairpin c-clip out of the side of the white connector and pull the teflon hose out. Fish the old o-ring out of the connector with a small hook or point if it didn't come out with the hose. Place the new o-ring over the end of the hose, snug against the brass collar. push the hose back into the coupling being careful to go straight and true so as not to damage the new o-ring. Some force may be required, be careful not to kink the hose. Blunt needle nose pliers to push the rear of the brass collar usually does it. Replace the c-clip and test for further leaks before reassembling.
Sep 15, 2011 | DeLonghi Magnifica 3300 Espresso Machine
When I hook of the water hoses to the back of washing machine and turn on the water, water spews out of hose
Hello Ifox5858,
I understand that when you hook up the hose to the back of your washing machine that the water comes out of the hose. The problem that you are having may be because of washers are missing out of the hose ends. You need to take the hoses off and look and see if you have rubber washers in the side that is leaking. The washers are standard water hose washers you can buy at any hardware store.
1. Place washer in hose
2. Install hose hand tight
3. Turn a quarter turn with wrench
4. Turn water on check for leaks if leaking slowly turn tighter to leak stops
This should fix your problem.
Thank you for choosing FIxya.com
Justin
Mar 16, 2011 | Fisher and Paykel Washing Machines
When driaining out water comes out
Where does the water come out from? From under machine or where the drain hose hooks to the drain. If it is coming out the drain where the hose hooks the drain is most likely stopped up. If coming from underneath could be a hose or the pump leaking. I have seen something like a screw get caught and wear a hole in the tub. Check around the bottom of the tub if there is water leaking around the bottom of the tub could be the tub seal is bad. Hope this helps.
Dec 23, 2010 | Washing Machines
Water leaking out of hose above water pump connected to motor whats that about
If the leak looks like it's coming out the 90 degree black rubber elbow then, this is a common problem.
check out
http://www.hotrodders.com/forum/coolant-leak-y2k-impala-169816.html
Apr 27, 2010 | 2004 Chevrolet Impala
1998 sunfire leaked out all the coolant, replaced thermostat. It is leaking from the bottom. What could it be.
could be the water pump or a hose, try to locate exactly where the coolant is coming from
Feb 26, 2010 | 1998 Pontiac Sunfire
I have a 1993 jeep cherokee limeted i had to change the water pump but now iam getting water spray from the bottom of the radiator but from the engine any 1 know what it could be?
Let it cool down and then get a flashlight (droplight bulb will break if it gets wet) and get under there and take a good look. From what you said, sounds like you have a leak from the lower hose. Check the end connections and make sure they are tight then start it up and watch.
Only other places it can leak that low there are from the pump gasket or the radiator.
Feb 26, 2010 | 1993 Jeep Grand Cherokee
Water leak at front of engine very small amount maybe a gallon every 2 weeks on 5.3 suburban 2002
check your hoses for poor condition and loose clamps. Check the gasket around your water pump as well.
Oct 05, 2009 | 2003 Chevrolet Suburban 1500
Water leaking from under the refrigerator, ice maker and water are NOT hooked up to refrigerator.
If no water is hooked up to the fridge then the leak is condensation. Check behind the fridge and make sure the drain hose is not plugged and that the pan is empty and clean. Make sure to disconnect power before servicing.
Jul 14, 2009 | Refrigerators
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
109 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
