Carrier 48sx gas pack. Won't turn on. No smell. No igniting sound. Blower fan works. How do I troubleshoot this?
  • 1,420 Answers
Remove the panel from the heater section, you will need to watch what happends as there is a call for heat. There may be a light on the control board that lights up or blinks to indicate a call for heat. The inducer blower (exhaust blower) will start. INn a few seconds after the blower starts, the igniter will glow orange. After a few more seconds the gas valve should open and the burner will ignite. If the inducer does not run, you may have a bad motor or control board. If the igniter does not glow, you could have a bad pressure switch, bad pressure switch hose or a broken igniter. If the gas valve does not open, you may have a bad control board or bad gas valve. If you get no light on control board, bad fuse, bad thermostat or bad control board.
Posted on Jan 03, 2011
Carrier high efficiency furnace blower not turning when thermostat set to on position
is breaker and emergency shut off on-- check ---thermostat /operating correctly--gas /valve on--thermocouple /in working order--gas valve /operating correctly---reset ,high limiter,safety 's //are correct and not popped ---fan working order ---
Oct 25, 2016 | Carrier Heating & Cooling
Why isn't it igniting?
Is the engine turning, do you know there is plenty of gas in the tank or do you smell it? If you smell it & the motor is turning it's already flooded. STOP, you oil is now 50/50 gas & oil if you have no spark. That's what it sounds like. It's a long shot without looking but you may need a coil pack, wiring to coil NG, ignition relay NG, wires, plugs ? You need to get it ckd out. Don't keep turning it if it's not starting. PS get an oil chg when all is well. Good luck
Oct 24, 2015 | Heating & Cooling
When the thermostat calls for heat sometimes the gas pack works fine and sometimes it doesnt work at all . the inducer motor comes on but the burners dont ignite . what could be the problem ?
Could be the igniter or the thermocouple. The blower has to start first and it does but it will run on endlessly without further action unless the igniter heats the thermocouple to open the gas valve and fire the burner.
Dec 15, 2013 | Carrier 3 Ton 13 Seer Commercial Gas Pack...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
I have a Trane xe 70. The Heat is not turning on. The ignitor will glow but NO gas or blower. I turn on the fan and the blower does work but not when HEAT is selected on the t-stat. Also the LED light...
Check to see if you get 24 volts AC at the gas valve from the circuit board when the igniter is glowing. If yes, bad gas valve or blockage in gas train. If no, bad circuit board or broken wire
Feb 07, 2010 | Heating & Cooling
My Carrier gas furnace (ser. 1903A41848) located in the attic, is five years old and suddenly won't light. IT cycles the fan when I cycle the power to the unit and seemingly attempts to ignite through 3...
try the fuse ,check the ignition element .do You have a drip leg on your gas supply line just before the gas pipe enters the furnace .if not your gas valve maybe folded .
Jan 04, 2009 | Heating & Cooling
Gas heater won't work
Which flame sensor did he replace? The pilot flame or the plenum temp. sensor.
Dec 14, 2008 | Carrier 38CKC036 Air Conditioner
Interior blower fan working intermittently.
sounds like ur blower resistor pack
Jun 08, 2008 | 1998 Buick Regal
Heating & Cooling Logo
471 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
