Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
How do i change the language on my hotpoint WMD 740 ULTIMA washing machine
SOURCE: I have just purchased a
OK the manual has it a little wrong.
What you have to do is switch the power off (not at the wall but on the machine itself)
then press the three buttons for around 5 seconds till you hear a beeb
next time you switch it on it will be back to the language selection
just follow the manual to select.
Posted on Nov 19, 2010
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
  • 1527 Answers
SOURCE: changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Posted on Sep 06, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
SOURCE: how do i change the language on my washing
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
Posted on Nov 07, 2010
Hi - I have a hotpoint wmd 740 ultima washing machine and have an error telling me to check water supply. The hose is fine, water pressure checked etc but the manual suggests it might be the inlet valve...
I don't know exactly where it is but it has to be early in the line. Follow your hose to the first component it goes into. That is where I would start to look for a filter. I am betting it is probably some sort of a screw on filter right on the first component you come across. It is not there just keep following the trail. You will have to take off the back on the unit to trace.
Jan 31, 2015 | Hotpoint Washing Machines
How do you change the drum bearing on a hotpoint ultima wmd 960
thier r 2 bearrings and a seal its called a bearring kit not very easy if u havent done it b4.
Jan 20, 2015 | Hotpoint Washing Machines
Hotpoint wmd 960 ultima,when press start button nothing happens apart from the clock starts count down to end of wash
if water starts but drum dont move.............
check the rear belt....if that is on then the motor needs new brushes............
easy fix ........... about £12 diy
cheers
Mar 22, 2011 | Hotpoint Washing Machines
Hotpoint wmd 942 washing machine - how do i change the language? I have followed the instructions but no luck. Help!!!
Thank yo so much. My manual fell behind the washing machine and it too heavy to move. So thanks again :-)
Feb 26, 2011 | Hotpoint Washing Machines
I can't change the language on the washing machine. How do I change it??
Key
wms=washing machines
wm=washing machine
IFYOUCANREADTHISTHENYOUSHOULDBEABLETOREADTHEFOLLOWING:
YOU CANNOT CHANGE THE LANGUAGE ON ANY WM.
Dec 12, 2010 | Hotpoint Ultima WD72 Front Load...
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
908 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
