Question about Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune isnt drying the clothes after they have been in for an hour?? my husband and i have always taken good care of the set, its like 4 or 5 years old. does a part need to be replaced an if so whats the part?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Check the inside vent duct on the machine and also the external duct all the way to the outside wall. I'm sure you will find lint buildup that is hampering the dry cycle.
Posted on Jan 03, 2011
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    My dryer takes too long to dry clothes. It could take up to 4 hours to dry a load of towels on high setting. What could be the problem?
    If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
    Here is the rest of this tip about Dryer Maintenance
    heatman101
    Oct 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    Neptune glass front takes 4 hours to dry clothes.
    make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
    Start there.
    Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
    The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
    how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
    Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
    Dryer not dring clothes completely
    need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
    Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
    I have a neptune drying center and it's taking 3 hours to dry
    Check the exhaust duct again. There must be a blockage, a kink, or a disconnected vent pipe.
    May 03, 2009 | Maytag Neptune MCE8000AY Electric Dryer
    NOt drying clothes like it should
    Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
    Apr 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
    Maytag Neptune sensor and time drying settings
    Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
    the dryer worked perfectly. V
    Feb 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
    Maytag gas dryer runs, doesn't dry
    Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
    Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
    Maytag Neptune MDE5500AY Electric Dryer Logo
    64 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
