Question about Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Having difficulty picking up reception using HDTV antennae. can you list the steps for setting up the TV
  • Emerson Master
  • 5,102 Answers
An HDTV antenna is a misnomer. Any antenna will be limited to receiving signals depending on the type of antenna and the direction in which it is pointed. What is the color rating (indoor/outdoor, distance and signal strength that it picks up)?
In addition, the EWC19T3 only has an analog tuner (NTSC or CATV) so what set top box do you have? The basic digital to analog converters available with the government coupon were SD converters.
Use antennaweb.org or tvfool.com to check the direction to point your antenna for the stations you want to receive. (If you share the antenna with other devices, you may need an amplifier). Antennaweb assumes an external antenna but is very conservative in the list of stations you will receive.
Use the Select button on the TV or the remote to swap from TV/VCR, DVD, and external input mode. Connect the antenna cable to your set top box and then the set top box either to the RF connector or the composite video connection on the back of the TV. If you use the RF connection, select TV mode and change channel to channel 3 or 4. Alternatively, select the external video input. Some have a pass-through that lets the local low power analog stations be read when the set top box is off.
For the TV's analog tuner programming, you need the remote (or a universal remote that matches the functions) to scan the channels if in TV mode. Press Setup and move down to Channel Set Up. Press Enter and go to Auto Preset and press Enter again. This will program the channels the tuner sees. (Please note to record, you need the feed to be on the RF connection.)
Scanning for channels may depend on the set top box. For mine, it was press Menu, go to the Channel Search, press OK and then wait. Some set top boxes have a SMART connection which added a RJ-45 connector connected to the SMART compatible antenna. In that case, you would scan for channels and then rotate the antenna and rescan. The unit would then remember where to rotate the antenna to get all the different channels.
I hope this helps.
Posted on Jan 04, 2011
  • Cindy Wells Jan 04, 2011
    If you need a replacement remote, try here (mind the wrap due to the long URL): http://www.remotes.com/remotes/servlet/r...
TV will not pick up the antenna
the input have to be set to the proper setting for an antenna to get reception .
May 11, 2016 | LG 50PG20 50 in. Plasma HDTV
HDTV not picking up local channels
Look to see in menu if set is set to Air or Catv (cable) if on cable anything is possible 2-13 but above that no or almost no reception.
Oct 25, 2012 | Tatung V23CLTT 22.92 in. LCD Television
Can my Panasonic TC-P42X1 receive digital channels without an antenna connected? It sounds like a stupid question considering its a high-def TV, but I'm having troubles getting the TV to pick up...
No.Tv can't pick up any reception or receive any free AIR broadcasting tv channels at all if tv have no antena hook up to a tv.Buy a better antena design to used like a Digital atenna,will solved this problems.
Aug 21, 2011 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Only picking up one digital channel
digital air signals are weak and fussy. They are easily lost by having trees or large buildings in the way too.
The best thing to do is install a long range roof top antenna and re program the set. Be sure to aim the antenna correctly. if you cannot use a roof top antenna you can try the indoor digital antennas,but less likely to work consistently
Jun 02, 2010 | Toshiba 40RV525U 40 in. LCD TV
We have recently moved into a new house. When moving our tv into the house it won't find any of the channels. The TV is a 44inch Sony Bravia. It is showing on the Tv a weak signal. We have brought a...
Are you trying to get the OTA channels? In that case you need to check out sites like antennaweb.org and tvfool.com. In many places, an indoor antenna will not work well for digital reception and both of these sites will recommend an antenna type for your location. They also give the direction to point the antenna for the stations. Antennaweb is very conservative in its listings. Tvfool gives significantly more information about all the stations around you that may be receivable with the largest antenna and correct positioning.
I hope this helps.
(Antennaweb.org lists only two digital stations in my location. With an exterior antenna, amplifier, and rotor, we actually get 10 in our standard setting and can get additional stations (losing the regular channels) on changing the antenna orientation.)
Dec 17, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My tv just stopped getting antenna reception today.
It is not possible clear picture use indoor antenna it is use cable tv then get a lot of channel enjoy
Sep 24, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Just the one TV freezes
hello, it possible if your sharing the signal to sometimes loose reception you should have a dedicated hdtv antena or hdtv cable service for your main tv.
you can check by removing all the other sets and see,
if it happens again then you need a dedicated hd antenna or signal. this should be better for you and your hdtv reception.
Dec 17, 2008 | Vizio VU37L 37 in. LCD TV
DTV connection
Have you tried http://www.antennaweb.org/aw/Address.aspx? This will show you the location of the HD broadcast towers for your local stations and my recommendation would be to use an outdoor antenna if you can. Picking up the reception is definitely about pointing the antenna in the direction of the towers.
Nov 10, 2008 | Televison & Video
Emerson EWC19T3 19 in. TV/VCR/DVD Combo Logo
156 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
