Question about Canon Pixma MP480 All-In-One InkJet Printer
I am getting an error Library/Printers/Canon/BJPrinter/Filters/Raster2CanonIJ/Raster2CanonIJ.bundle/Contents/MacOS/Raster2CanonIJ failed. I just installed the printer and I am trying to print.
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
SOURCE: canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Posted on Dec 13, 2008
SOURCE: Canon mp210 problems print spooler error
Error EP22
Posted on Feb 10, 2009
antking
  • 51 Answers
SOURCE: canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
Posted on Apr 09, 2009
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Posted on Jul 08, 2009
Everytime that I export to the ipf6100 plugin in cs6 it generates a crash report and will not print.
Process: GARO IOS Application [2876]
Path: /Library/Printers/Canon/GARO/Utilities/GARO IOS Application.app/Contents/MacOS/GARO IOS Application
Identifier: jp.co.canon.GARO.IOSApplication
Version: 1.01 (1.01)
Code Type: X86 (Native)
Parent Process: launchd [201]
Date/Time: 2013-11-12 17:05:56.407 +0100
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Interval Since Last Report: 82539 sec
Crashes Since Last Report: 74
Per-App Interval Since Last Report: 497 sec
Per-App Crashes Since Last Report: 26
Anonymous UUID: C5192828-9918-4F37-8DAF-4C78AFC9A28F
Crashed Thread: 5
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Library/Printers/Canon/GARO/Utilities/GARO IOS Application.app/Contents/MacOS/GARO IOS Application
__TEXT 0000000000001000-0000000000007000 [ 24K] r-x/rwx SM=COW /Library/Printers/Canon/GARO/Utilities/GARO IOS Application.app/Contents/MacOS/GARO IOS Application
Feb 25, 2013 | Canon IMAGEPROGRAF IPF6100 InkJet Plotter...
Printer Problem: Epson Stylus Photo R340. Hello, I upgraded my IMac G5 Intel Core Duo to Snow Leopard Version 10.6.8, and now when I try and print pages I get an error message - Error:...
HI, That's error need software driver reinstall. to download software driver for Mac operating system click the following link http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=60586&prodoid=58654762&infoType=Downloads&platform=Macintosh If finish downloading, double click software driver. just read software instruction step by step installation guide.
Hope can help you. Regards.
Jul 10, 2011 | Epson Stylus Photo R340 InkJet Printer
Good day, When I click on Safari,it comes on then,a message comes up, saying that it could be a ct_plugin,how can I fix this problem ?
/Library/InputManagers/CTLoader/ct_loader.bundle/Contents/MacOS/ct_loader
Go to /Library/InputManagers and move the ct_loader.bundle file to the Trash and relaunch Safari.
"Support/Conduit/Plugins/cttoolbar.bundle/Contents/MacOS/ct_plugins"
Also, go to ~/Library/Internet Plugins and remove anything CT Loader related there.
Possible help here also. http://forums.macrumors.com/showthread.php?t=790334
More suggestions here. http://discussions.apple.com/thread.jspa?threadID=2090864&tstart=0
or use another computer to download safari for mac and put it on a flash drive and install it on ur macbook.
Mar 17, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Internet page does not stay loaded. error message something wrong with ct_plugins plugins
go to /Library/Application Support/Conduit/Plugins/cttoolbar.bundle/Contents/MacOS/ct_plugins right click on it and click "show contents" or "show package contents". delete the plists listed here http://discussions.apple.com/thread....sageID=9913691
Apr 13, 2010 | Apple Computers & Internet
Epson Stylus printer is connected, but will not print! Error message says: Error: /Library/Printers/EPSON/InkjetPrinter2/Filter/rastertoescpll.app/Contents/MacOS/rastertoescpll failed Have tried several...
Found this on the Web. If you find helpful, pls rate me.
Here is the link for all the discussions regarding this error.
http://discussions.apple.com/thread.jspa?threadID=2199441
Welcome to Apple Discussions
Go to: Apple > System Preferences > Print & Fax > Print and reselect your printer in the Default printer: box near the bottom of the panel. Then next in the same Print & Fax preference panel, select Open Print Queue: and Delete all the Jobs in the Status box and try printing something again.
reply
have no idea exactly what that error means, but now I suspect that when you "Trashed the EPSON folder in HD\Library\Printers\Epson" you trashed an important part of the OS X and not the installed Epson software.
If you have a backup Time Machine, a backup clone or that file is still in the trash you need to restore it "HD/Library/Printers/Epson/InkjetPrinters2 or whatever" back to the correct location, run Repair Permissions and hope that fixes it. If not then backup all your files, because it seems like you may have to completely reinstall the OS X....
Good Luck.....
Mar 03, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Trying to print... Error message > Error: /Library/Printers/EPSON/InjectPrinter2/Filter/rasterescpii.app/Contents/MacOS/rasterteoscpII failed. What does this mean? What is required to fix it?
Was advised to uninstall the application programs for the printer. To do this, I put the disc in, for the printer, started the install. At the start of installing, the option to uninstall was given. Disconnected the printer cables from the computer (ethernet and modem cables). Did the uninstall, then continued to install the printer applications.
While doing the install, updated the OS drivers for the printer.
Once the printer applications were installed connected the printer. It now works again.
Dec 13, 2009 | Epson Stylus Photo R300 InkJet Printer
Get this Error message:
Ensure that directory is delete when you uninstall and there mates ie........ /EPSON/......whatevers.
Use a new set of downloaded drivers from elsewhere, not the same ones if you can help it and if you cant it is because they dont really exist, ones that work will be many places....... ensure full compatability to your mac OS, I can't help you much there but I can assure you it isn't a problem with the printer it is a mac/driver issue. Hope thaty helps a little cheers
Nov 06, 2009 | Epson Stylus 1400 InkJet Photo Printer
Need MAC Snow Leopard printer drivers for;
I had installed the Mac X snow leopard, but every time i tried to print with mi HP laserjet P1005 i have this error
P1005 i have this error Process: PrintJobMgr [416]
Path: /System/Library/Printers/Libraries/PrintJobMgr/Contents/MacOS/PrintJobMgr
Identifier: PrintJobMgr
Version: ??? (???)
Parent Process: cupsd [28]
I reinstalled the Hp drivers that I could find on the internet but the problem persist
Aug 31, 2009 | Apple Computers & Internet
Canon Pixma MP480 All-In-One InkJet Printer Logo
320 people viewed this question
old marine
old marine
