Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
Need lower guard kit, seems to be obsolete everywhere.
  • Skil Master
  • 885 Answers
Go to www.ereplacementparts.com. They have two SHD77M saws listed but both have a lower guard with part number 1619X01182 for $8.42 (+S&H of course) but a saw worth fixing.
Posted on Jan 03, 2011
Cannot raise or lower 115johnson outboard with manual relief valve open
If, even with relief valve open you can't raise or lower the motor by hand, your tilt tube is stuck.
remove your steering cable.
Remove the 2 big nuts on the tilt tube;
unbolt the engine from the boat
unbolt the trim/tilt system from sb and pt bracket.
Remove brackets. Remove tilt tube from steering bracket
Clean everything
Replace the bushings
Use triple-guard grease everywhere on reassembly
Jul 31, 2017 | Boating
Is there a blade guard that will fit my Jet Shopline 10 inch Table Saw. The original is obsolete.
check out the Beisemeyer, it works well and we sell a lot of them.
Oct 14, 2014 | Saws
Ford shift cable
Find a reputable trans. shop near you, they may be able to find or modify one to make it work.
Jan 09, 2014 | Ford Cars & Trucks
Replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Mar 24, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
Repair spring to lower guard to spring back on dewalt 18v dc390 saw
You may be able to salvage the torsion spring that is there. Sometimes the end will break off and you can bend yourself a new end and just stick it back into the retaining hole in the housing or guard. There may be damage to the guard which will not allow you to just bend the spring to make a new joint. Either way, you need to know what you are dealing with. First remove the blade if you haven't done so already. Then remove the bumper (rubber piece) that stops the guard from returning too far. Next you will need a pick or a small flat head screwdriver. Look around the hub and you will notice a retaining ring. You will have to use the pick or screwdriver to get the ring started. Look for a little tab around the perimeter of the hub. You will have to work that tab out and make sure you keep your pick or screwdriver under it. Then work it around and off the hub. Then you can remove the guard from the hub. The spring is located under the guard and is a torsion spring. Look for damage to the guard and the housing as well as the spring. If there is any question to the integrity of the guard you should replace it. The part number for the torsion spring is 612517-00 ($1.50), the retaining ring is 150383-00 ($1.50) just in case you break it, and the guard number is 611925-00 ($6). If you have any questions please post back.
Oct 28, 2009 | Dewalt DC390K 18v Cordless Circular Saw...
How to replace Ryobi circular saw CSB140LZ lower guard assembly
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Sep 28, 2009 | Ryobi Saws
Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
Jun 20, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Andis masters are chewing my guards
Stop using speedo guards and get yourself an oster 76 and all the blades.
Aug 16, 2007 | Andis 01690 Hair Trimmer
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
