Question about HP w1907 LCD Monitor
I have a w1907 HP monitor. It keeps displaying a small box in the middle of the screen that says osd lockout. I am still able to get online and use my computer normally except for this box in the middle of my screen. Tried trouble shooting with pressing and holding the power button and the menu button and it is still doing the same thing.
    Sergeant:
    Champion:
  • 217 Answers
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work. To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Posted on Jan 03, 2011
  • elpompudo Apr 06, 2011
    Thealfords03 Hi I had the same problem but luckily I was able to fix it. If you press the menu button down for 10-15 seconds The OSD lockout scren will go away and you will have access to the regular menu. When I did this I noticed that on the menu screen, all the menuoptions would become highlighted one by one as if I press the " - " button on the monitor. This gaveme the conclusion that the button was the culprit. The button was not stuck because I could press it and it would go in and pop back out. So I removed the base plate (3 screws) and then I found that on bottom 2 corners you will see a **** on the black inner plastic (use a flashlight) Stick a flat tip screwdriver there and gently pull the black frame out. Once you do that you will gain access to the panel that hold the 4 buttons. Remove the plug and separate the board with the buttons from the black plastic base by prying the plastic clips back. If your faulty button is the " - " button like mine then gently pry the metal cap thats on the top of each button until you remove it ( If done carefully you can replace it by pressing the metal plate back on) Once you remove the metal plate you can remove the actual button. Look down to locate a thin copper concave circular plate. I used a metal polishing paste to shine the copper concave plate on both sides once shined place it back in the button and put the button inside then press the button downto ensure the button goes down and pops back up. If it doesnt then gently press the middle of the copper plate with the tip of a screwdriver and try it again. If the button goes down and pops back up you can place the metal plate over the button and press down to fit down in place. Reassemble and this will fix your issue. I was so glad I got rid of that annoying OSD lockout white screen once I did this technique. Good luck and post something if it worked for you!
    Problem Solver:
  • 5 Answers
Posted on Apr 06, 2011
Whats an osd lock out
On Screen Display lockout. A user function that can be set to prevent tampering.
Refer to the user manual for instruction as to how to select and deselect this function.
Jun 08, 2011 | HP w1907 LCD Monitor
Osd lockout
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | HP w1907 LCD Monitor
"OSD lockout
Hold the menu button for 10 seconds
Jan 25, 2010 | HP w1907 LCD Monitor
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
Osd lockout
osd is ON SCREEN DISPLAY.
Jun 10, 2009 | HP w1907 LCD Monitor
OSD Lockout bananas
Sounds like a button on the monitor is stuck in the depressed position.
May 30, 2009 | HP w1907 LCD Monitor
OSD Lockout bananas
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 23, 2009 | HP w1907 LCD Monitor
Osd lockout
If you encounter an OSD Lockout error with your monitor simply try the fixes on this page:
http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Mar 27, 2009 | HP w1907 LCD Monitor
Fix-4u
Hi...there,
Well, can you still open OSD. If so, step 1 press a button on your monitor to open your on screen display and used the - (- +) to guide you to OSD settings when you get there press step 1 again to open it and used the - to scrolled down to OSD lock settings and press step 1 button to selecting NO to unlocked. And that it!
Nov 30, 2008 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
508 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
