Question about Refrigerators
Samsung refridgerator model rf465abbp--freezeer set at -2 asrecomended---fridge set at 38 as recomended freezer works but is forming frost on inside -- fridge not cooling -- shows 59 degrees to 63 degrees
    Genius:
  • 1,456 Answers
Hello
samsung has had problems with There Condenser fan overheating,open up the refrigerator and check the evap/heater assembly if it has frozen over.
Defrost the entire fridge and then proceeded to test the temperature sensor (yellow wire harness) and the resistance readings if they are okay also test the defrost heater (red and white harness) and the and test the thermo-fuse
replace the upper and lower thermistors and the thermal fuse if anyone is not giving the right readings
Lastly take apart the fresh food segment you will see the evaporator fan,ensure the fan is working perfectly and that it is not all iced up as this allows very little air movement.replace this fan and the thermistor near the top light and clean out all the ice.
Posted on Jan 03, 2011
We have a e381t model refridgerator/freezer. there is a rattle/scraping noises coming from the fan in the freezer part. There is ice behind the protective sheet that separate the fan from the main area. Is...
If there is noise of the fan rubbing with the frost build up on the freezer then it is confirmed that the defrost timer is faulty. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 17, 2011 | Fisher and Paykel Refrigerators
Top freezer working fine. borrrtom fridge not cooling
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Sep 05, 2011 | Samsung Refrigerators
For Samsung Refrigerator SR-L629EV my freezer
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
Fridge model 4244 getting too cold
Top of Form
Jul 08, 2011 | Samsung Refrigerators
I have a samsung refrigerator rl33sbn . Where the freezer is at the botton, the freezer cooling where frost build up on the condensor the refridgerator remain warm. I check the fan is good when i tested it...
Top of Form
Jul 08, 2011 | Refrigerators
Fridge temp set to 38 is blinking,,reset unit
I had a similar problem, paid a technician $90 to tell me to defrost the entire unit for 15-20 hours, and now it works like new. It is supposed to self defrost, but with poor circulation in the freezer (simply caused by too much stuff in there) the unit frosts up. This caused a rising temp in the freezer leading to inconsistent temps.
Anyone reading this with a similar issue, save your money and defrost it overnight. You should see a pool of water in the bottom of the freezer after defrost if this was the problem.
Jul 24, 2010 | Samsung RB215LASH
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
RS21DGRS SAMSUNG SIDE BY SIDE REFRIDGERATOR
hi thanks for the question it might be a problem with a little frost on the freezer wall fridge not defrosting check the freezer wall with your hand,will feel some frost if this is the problem thanks the appliance doc you
Sep 17, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
