Question about Hasbro Bop It Bounce Game
Need replacement ball for bob it bounce - Hasbro Bop It Bounce Game
I have a thump noise when i hit a bump. I wrecked my truck and changed upper control arm. It still makes a thump. Now it looks like the bott
Jack up the truck so the wheel in question is off the gorund. Grasp the top and bottom of the tire and wiggle it. If there is movement, the lower ball joint may be suspect. You should be able to "feel" the ball joint with you hand while pushing/pulling the bottom of the tire in and out. If you feel "slop", the ball joint is bad.
The sway bar link may be broken or defective in some other way. See that the torsion bar is secure.
The a-frame bushings are good, right?
A bad shock can be tested by pressing the bumper down with your kneew. The vehicle should not bob up and down when you release the force of your knee. It should rise up and may move back down a little, but not bounce two or three times.
You will find the source of the noise. It's not rocket surgery! Good luck!
Mar 05, 2015 | Cars & Trucks
My daughter says there is a toy that is a ball that bounces on the water. Is she right?
Yes she is - the Waboba surf is a great toy. It's brilliant fun in the pool and in the sea with all the family as it's a ball that actually bounces on the water.
Check out this info about it;
http://www.amazon.com/Waboba-Surf-The-Ball-Bounces-Water/dp/B004RGU0SK/ref=pd_sim_sg_6
Feb 28, 2013 | Toys
The front suspension bounces and makes noise
if its bouncing the shockers are goosed need replacing for the noise probably just the shocks but get the lower ball joints checked springs and track rod ends hope this helps ivan
Oct 25, 2012 | 2002 Kia Spectra
Bouncing balls won't load on. Facebook
Call Zynga's Phone#: 800-762-2530
How to reach a live person: Dial 3 when recording begins
Aug 15, 2012 | Apple iPad 32 GB 3G Tablet PC
Aside from what they are made from, how are soft gel medicine balls different from other medicine balls?
Soft gel filled medicine balls neither float nor bounce. This makes them the perfect tool to use while working out on any type of surface where you wouldn't want the ball bouncing back (such as on a trampoline).
Aug 05, 2012 | Exercise & Fitness
Are there different types of medicine balls?
There are several types of medicine balls, all designed with a different purpose. Some are designed to bounce, while other are specifically designed not to bounce so that you don't have to chase them around. Some balls have a grip to make it easier to catch, while others have a smooth outer surface.
Does Hasbro games make replacement balls for the Bop It Bounce?
Yes they do. Just go to Hasbro.com and follow the links.
Jan 22, 2011 | Hasbro Bop It Bounce Game
Vibration in front end while driving,replaced tires,balnced,ball joints have no movement horz,how do you know if struts are bad
to check for bad struct bounce the front iend up and down very hard, after you stop it should stop after one more up or down bounce, if it keeps moving the struts are no good.
Oct 02, 2009 | 1990 Chevrolet Cavalier
Sounds like a ping pong ball bouncing when it turns on
I am having the same problem. I don't know if it's normal or what. Just got the fridge about a month ago. Maytag french door freezer on bottom. Every so often--I guess when it comes on like you say, it really does sound like a bouncy ball or ping pong ball...
May 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hasbro Bop It Bounce Game Logo
442 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
