Have lost instructions for my bush 5 button mouse. Have fitted new batteries and placed USB r/t stick but mouse doesnt work. Pleas advise. thanks.
    President:
  • 2,047 Answers
First thing is to determine if the mouse in itself is the bad unit or the USB stick for the mouse. When batteries were inserted does the mouse itself come on? If the mouse comes on then the mouse is okay. But if on the other hand the mouse does not come on then it is either the batteries are not strong enough to power the mouse or the mouse is damaged and mostly it cost more to fix the mouse that to have it replaced.
On the other hand if the mouse powers up and the system does not recognise the USB stick then this is a software issue and therefore should be dealt as such. What you do in thiis scenario is go to the program files on your system and delete the installation files for the USB stick of the mouse restart your PC and plug in the USB stick the PC should recognise it this time and install it for use by the mouse.
Hope this solution has been helpful?
Posted on Jan 03, 2011
Hello how do i get the wireless mouse to work on my laptop? i have it plugged in but it doesn't work
1. Put in the batteries Find the battery cover and slide it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
2. Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
3. Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily pushable by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
4. Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without not working very well is about 9 feet (2.7 meters), so keep that in mind.
5. Test your new mouse.
- If you plugged into the mouse port, restart your computer manually.
- If you plugged it into the USB port you may begin using it.
- When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this help. Goodluck!
Mar 27, 2011 | Computers & Internet
I have a logitech mouse (came w/Dell computer) . When I put a new battery in it, the green light comes on for a second and then goes out. It doesn't appear to be working at all. I hit "reset"...
The new battery may be new old stock & have a low voltage. Cold weather doesnt help fully energized batteries. Check it with a battery tester Volt Ohm meter. Some mice have tiny buttons on the USB stick and mouse. If the problem persists call the Mfg or return it to the place of purchase and demand a refund or exchange.
Jan 25, 2011 | Logitech Cordless Mouse
Bought a logitech wireless mouse for my new laptop from ebay. It came with no instructions. I have no idea how to use. It has no batteries but a flash drive
By a flash drive I'm guessing you mean a USB stick. What you need to is find a USB port on your computer/laptop and plug it in. There might be a synchronize button on the mouse and USB stick if so you need to press them both and then your mouse should be working. I hope this helps. :)
Dec 04, 2010 | Logitech Cordless Mouse
I am trying to hook my mouse up to my new laptop but I can't get it to work. Please help.
1.Put in the batteries Find the battery cover and slide it off. Insert the appropriate batteries.
2.Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
3.Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily pushable by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
4.Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without not working very well is about 9 feet (2.7 meters), so keep that in mind.
5.Test your new mouse.
* If you plugged into the mouse port, restart your computer manually.
* If you plugged it into the USB port you may begin using it.
* When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
This should help you to fix the problem.
Mar 03, 2010 | Logitech Cordless Mouse
New batteries, power light on, no activity from mouse at all. Batteries went dead, installed new batteries now nothing works. Power light is on.
try holding down the reset button for 5 seconds. usually that will re-establish the connection to the USB dongle
Nov 24, 2009 | Logitech Cordless Mouse
I have bought a saitek m80x wireless notebook mouse for my laptop, the man at the shop said it would work on my laptop i have plugged the usb in it said it installed the mouse is on (glowing red...
Cracked it! Instructions and website are useless!
What it does not tell you to do is:-
1. plug in wireless usb part and let windows install.
2. put batteries in mouse, it turns on automatically but turn it off by pressing the button underneath for 3 - 5 seconds.
3. Press the button on the wireless usb stick until the green light on the stick comes on. When you release the button it stays on for about 10 seconds. In the time that the green light is on turn on the mouse with a short press on the button underneath to register with the wireless usb stick.
4. Well it worked with mine after I figured it out - no thanks to the instructions. tried on vista ultra and xp home.
Oct 03, 2009 | Computers & Internet
I just purchased the mocrosoft weireless mobile mouse 3000, put in a new battery, followed the 4 step instructions and the mouse will not work, i have resynchronized the mouse and the usb port but still it...
Once you resynchronize both receiver and mouse,do the following: Take off battery next look for a tiny thin button that protrudes in one of the sides where the receiver is placed in mouse, while pressing down this button put a new and fresh battery releasing simultaneously the button.
Unless said button is stuck press it gently down a couple of times, it must be out for as long as the receiver in the USB port. Good luck!! Chawah.
Aug 05, 2009 | Microsoft Wireless Notebook Optical Mouse...
Cordless mouse?
Try pushing the connect button on the bottom of the mouse. Also check to see if there is a button on the reciever. If so, you should press that button first. Make sur there is no tab sticking out from the moust that needs to be removed. If this doesn't work, reply with the brand, and model of the mouse.
Feb 18, 2009 | HP Wireless Optical Mouse
Not working
If there any lights on the mouse when you put new batteries in the mouse? If yes then you can still fix it. On the usb controller of you mouse it will have a button on it. Press that button first and then press the button under the mouse. Repeat a few times and see if mouse responses. Then if nothing happens, unplug the usb controller and place it into another port. Repeat the above process and see what happens. Should work fine.
Aug 09, 2008 | BenQ M310 Wireless Mini Optical Mouse
MICROSOFT WIRELESS MOUSE FOR LAPTOP DOESN'T WORK
There's also a connect button on the USB connector. Plug the connector in and press the connect button underneath until the light flashes. Release the button and click the connect button on the mouse until the USB light is steady.
May 16, 2008 | Targus PAKP003U Keyboard
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
